Headlights in the dark
Is a Planet Bike Bright Spot 3 good enough for night commuting (on some poorly lit side streets)? If not, I can still exchange it - but then I need some advice on which light to order
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
Probably not. You need a "real" light to see on dark, poorly lighted streets.
Rides again
Bikes: Giant OCR T, Trek SC
Don't like any of them. best is
https://www.nashbar.com/profile.cfm?c...eid=&pagename=
Swap for something else. I think their lights are to be seen but not to see while riding at night.
Retrogrouch in Training
Define "poorly lit"? How fast do you want to go?
I have a CatEye 3-LED light that's mostly a be-seen light, but it provides some path illumination when necessary, including some sections of unlit and poorly lit multi-use path. However, I do have to pay very close attention and/or slow down considerably.
I have no problems on the street.
Rides again
See all the gory details at https://www.mtbr.com/spotlight/lightshootout/
Bottom line: cheap lights == slower speeds at night. better lights == faster speeds at night.
So choice between low cost or low riding speed. Nothing to prevent you from starting with a weaker light and when get funds change light and enjoy the extra speed that new light allows.
I think most of us compromise on lights at first and slow down until we can afford the top $400 to $500 lights.
My take on the best:
Nightrider 50. $50, 7 watts, good for 10-12 mph
Light and Motion Commuter, $80, 10 watts, good to 15 mph
https://www.nashbar.com/results.cfm?c...it=y&pagename=
Performance duo, $150 10+20 watts, good to 20 mph
https://www.performancebike.com/shop/...tegory_ID=4320
Light & Motion Lion, $470, good to 25 mph
When you're ready for the top end lights and can handle the speed, then study carefully the light comparison pages. Good sales can be found in the winter as bike stores regularly have specials in the middle of winter as most don't bike then and don't visit the stores.
Until then, do as most of us do and get the best you can for your current budget. Don't forgot the cheapest initial cost could turn out to be expensive as you have to keep on buying disposable batteries. Cheaper than fuelling up a car, but still a nuisance. If you can get rechargeable battery, that's the most economical way to go.
Good luck.
Good luck.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Good luck.
Good luck.
Good post, the link to the light comparison photos is what most people want to see I think. There are many lights reviewed at mtbrider.
All good lights, there are other good lights too.
I want to reinforce the rechargeable battery idea. Over the cost of one season or even less you may save money compared to using replaceable batteries. The more you ride at night the more you save going rechargeable.
I did what almost everyone does, just like you describe, I upgraded over time to better, more expensive lights. In hindsight I would have saved a bunch of money, if I bought a better light earlier on. For some reason that is not human nature. If I just went out and bought a 10w HID first I would have saved enough to but another one.
I get all the mail order catalogues. It seems that most of the time Performance Bike, and Nashbar have a decent rechargeable halogen light in the "Sale" section of the catalogue for a reduced price.
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
Most LED's are under powered and inadequate for night use other then to be seen. You can get a Cygolite Metro that has 13 watts of power but useds 6 D bats (either throwaways or rechargeable) for only $48; or step up to the Rover NiMh Extra that has 16 watts rechargeable but cost $78.
I have the Metro and like it just fine.
I just bought a 10 watt road rat made by nite rider on performance. Love it. I bought one of those LED lights as a backup. Let's just say I hope I never need it (way too dim). I only paid $60.00 for my halogen light. Good deal.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Tomorrow I should be receiving at work the $150 (for less) Performance light linked by HiYo (I love online coupons...). The way things are going at work it looks like I need today. <grubmle>
Rides again
Enjoy. The earlier versions of this light had problems with the connector between the battery and the light being too lose. Now it is very tight. You might think you need a pliers to disconnect but a jiggle back and forth will do the trick and no pliers is needed.
Bikes: Surly CC
I'd recommend a https://www.zyro.co.uk/lupine/products.asp?code=LUNMLI for your helmet light and a https://www.bikelights.com/Products/arc_liion_ultra.htm x2 for your standard handle bar lights. Now, this might not be enough to shut down solar powered streetlights in your area so you could (with minimal weight) add this 12v badboy https://www.creativevideo.co.uk/gimme..._ultradaylight. The only issue you might have is mounting, but I'm positive someone here could help you jerry rig something. That's a combined, what, 50 watts of HID lighting power. Now, go forth and ride at the 50 miles per hour you do during the day with your safe lighting (*sarcasm*)
I'd recommend the Lights and Motion light honestly, although I think if you were to set up with what I suggested you'd not only get a ticket, guaranteed - you'd also have every UFO fatalist following you and trying to shoot a picture of your flying saucer (considering I think you'd create a star burst in your region with that kind of lighting).
Another high point, reptiles would follow you thinking you were the sun! See, now you'll be a god! Ra.
Bikes: Surly CC
Wait, I found a better helmet light!
https://www.modulom.com/english/prodotti/shine150.html
Now, you'll be seen and see!
I'm super new to biking yet and my headlight isn't even here yet, but for what it's worth I spent like five hours on Sunday reading message boards and reviews and all kinds of stuff before I settled on this:
https://www.bikemannetwork.com/biking...THEDCYG/LT7804
The next choice would have been the Light and Motion Commuter, but for about 20 more bucks I got a double light with 15 more watts!
Bikes: Peugeot Hybrid, Minelli Hybrid
I have a Careye EL300 light on the handle bars and a Plinet Bike spot at the bottom of the left fork. The light on the bottom of the fork gives good light imediately in front of me, and the one on the bars gives some light further out. This gives enough light for 12 mph in the dark. I may add another on the other fork. These lights are not expensive or heavy, and are cheap on batteries.
34x25 FTW!
DancesWithSUVs
Quoted: 7 Post(s)
I've got one of these:
https://www.performancebike.com/shop/...TOKEN=37704918
I'm quite pleased with it. Plenty of light to see with,single compact unit,waterproof,good battery life,common AA batteries(you can use rechargable ones),and way cheaper than those halogen jobs. Plus for the same price you get a red blinky included.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
I've been using the Performance Viewpoint dual setup for about a year now (most during the winter but I also enjoy riding at night in the summer). 90% of the time I've used it, I've been only using the 10W bulb. With that amount of light, I've felt comfortable on all but the fastest downhills. The 4 hour runtime they quote is real and may be conservation. I've gone at least 3.5 hours without having to recharge. The setup is reasonably light and I can make the battery pack fit on my frame along with my Road Morph pump and two water bottles. It's tight but it works (54cm compact frame). Extra velcro straps would be nice but I just use a large twist tie (came on some computer stuff I bought) to hold the extra battery wiring to the frame. The plug for the battery is very tight. I have a small flat blade screwdriver that I use to pry it apart. I would replace it with a sealed automotive connector but if it ever breaks, I don't want my warranty voided. I'd recommend this light, especially in lieu of the 20% coupons out there (I paid around $100 for mine during a sale last fall). If I see the same deal again I'll be buying another setup so I don't need to swap it between my commuter and road bike and I can always have a charged battery then.
Hope this helps.
Hope this helps.
Guest
Posts: n/a
Quoted: Post(s)
Planet Bike Insight 15 W
