Sugino 75 cranks + 109mm spindle + Italian threading... does it exist???
Old 08-26-05 | 10:41 PM
benk0's Avatar
If you don't look good...
Bikes: 1993 Cannondale Track
I've searched the forum archives... however I cannot find a definitive answer.
My LBS is recommending trying the Shimano UN72/73 in 107 and 110 to see which will work... however, I know for a fact I need a 109 with the ISO taper. I currently have an old Sugino BB with a shimano 115mm spindle (WAY too long for the S75's) but for some reason it works with my vintage Stronglights.
I would love to run my new cranks but my chainline says, "hells no".
Help?
Thanks.
benk0 is offline
Reply
Old 08-26-05 | 11:11 PM
20 Anniversary
hmmmm. i just ran into this myself. i couldnt get the old to work wiith the new. my situation was opposite yours. i had the stronglight cranks and needed more room. the old spindle would not work with the new bb. so i had to replace it. i am not sure if it is the case with the new spindle working with the old cups. good luck. let me know what you find out.
d
dwylie75 is offline
Reply
Old 08-26-05 | 11:57 PM
checkthat's Avatar
horizontal drop out
Those cranks are weird... I tried a Sugino bb with mine, and the chainline was off by several mm's. Go for the 107. Myself and others I know use a Campy 111, which also works fine.
checkthat is offline
Reply
Old 08-27-05 | 06:18 AM
Jose R's Avatar
20 Anniversary
Bikes: Custom DeanUSA El Diente CTI, Rich Adams Track, Johnny Coast Fixed, Argon18 Gallium Pro
Shimano BB-7610
This BB comes in english and italian. Its sealed cartridge design.
I've ordered from Swinnerton before. Overseas shipping is kinda pricey, but you don't have much choice.
I use this BB with my Sugino 75 cranks. No chainline issues.
Jose R is offline
Reply
Old 08-28-05 | 09:04 AM
travsi's Avatar
i don't stop
Bikes: soma rush, giro
woah, you don't mean that you use the sugino 75 with a campy bb, do you? the campy taper is different than the sugino. you should only use shimano, sugino or other bb with jis taper with sugino cranks.
travsi is offline
Reply
Old 08-28-05 | 09:48 AM
(Grouchy)
20 Anniversary
i use a campy BB with my suginos and have never had a problem. i've also used my dura ace cranks on a campy BB without issue, and swapped them back onto a shimano BB.
OneTinSloth is offline
Reply
Old 03-13-07 | 09:26 PM
andre nickatina's Avatar
not actually Nickatina
A very credible mechanic today was telling me that you should only use Campy or Sugino 75 BB's with a Sugino 75 crank. There's also this thread where at the end someone emailed Sugino and they said about the same thing. I guess I'm about to switch out my UN54 for a Campy BB. This seems like a big contrast to what bikeforums has led me to believe, but if Sugino AND a very credible mechanic are saying the same thing, it seems to me that's truth.
andre nickatina is offline
Reply
Old 03-13-07 | 09:39 PM
A little North of Hell
108?
https://www.philwood.com/Price%20List/P11.pdf
Soil_Sampler is offline
Reply
Old 03-13-07 | 10:42 PM
baxtefer's Avatar
Cornucopia of Awesomeness
ugh. not again.
baxtefer is offline
Reply
Old 03-13-07 | 11:00 PM
Originally Posted by baxtefer
ugh. not again.
**** it, I'm just trying to have things set up proper.
Reply
Old 03-13-07 | 11:19 PM
jamey's Avatar
ok, i've had a few drinks so bare with me. if i understand your question correctly, just buy whichever cups you want and throw the sugino spindle in there. if i totally read this wrong then i apologize....sike!!!!
jamey is offline
Reply
Old 03-13-07 | 11:32 PM
just a heads up, i bumped this thread to ask my own question out of not wanting to start a new thread, otherwise it's a year and a half old thread.
Reply
Old 03-14-07 | 05:40 AM
mr_tom's Avatar
I'm using a Sugino 75 with a Shimano 110mm BB and a Phil doublefixed. All lines up nicely.
mr_tom is offline
Reply
Old 03-15-07 | 09:31 PM
hmm, not trying to start debate but just letting you guys know:
i switched over to a campy 111mm BB on my drivetrain (sugino 75's, formula hubs, EAI 1/8 cog), and the chainline is perfect, there is no more clicking noises, the crank is sitting COMPLETELY on the spindle as opposed to really sticking out and exposing the spindle with the UN54, and things feel a little smoother. i really don't think it was a typo on the sugino website where they listed the 75 as needing an ISO taper. sure, you can run it with JIS like a shimano BB but it seems less than optimal as compared to now. i don't know if that's why skids are feeling easier today, or if it was my straps not loosening this time, but that was another noticeable thing.
anyways, carry on.
Reply
Old 03-15-07 | 09:48 PM
onetwentyeight's Avatar
blah
sugno 75 bb's come in italian threading. they're hard to find, but they exist.
edit: i think business cycles has em.
onetwentyeight is offline
Reply
Old 03-15-07 | 10:05 PM
My understanding is that all NJS parts must be interchangable. I don't see why a Shimano BB wouldn't work with 75s. With a UNxx 110, you're "off" by a 1/2mm, which is probably closer to 42mm than your rear hub/cog setup.
moki is offline
Reply
Old 03-15-07 | 10:11 PM
the shimano BB worked fine as far as perfect chainline, but the crankarm was not sitting all the way onto the spindle of the BB like it is now with the campys, and i was having issues with clicking noises (could partially be related to incompetent installation on my part, but the driveside arm was definitely right because the chainline was perfecto, who knows). the chainline is perfect on the 111mm bottom bracket just as it was on the 108mm, i think you need to factor more into the equation than just the lengths, because the crank is sitting closer to the frame on the campy's.
anyways, are NJS parts all interchangeable or is that just an assumption? and un54's aren't even NJS so how does that factor into this, do dura ace bottom brackets have the same taper or what?
Reply
Old 03-16-07 | 05:18 AM
fixedpip's Avatar
asleep at the wheel
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
NJS is just a stamp saying the part has been official approved for Keirin racing in Japan. It says nothing about compatibility. Campagnolo had some NJS parts for example and a Campy NJS locking could not be used on a Dura Ace track hub etc.
When you're talking about cranksets, you're really talking about 'taper'. The two main standards are JIS (Shimano) and ISO (Campy etc). It just so happens that the vast majority of NJS cranksets are JIS taper.
But it does seem that there is some debate over whether Sugino has a true JIS taper. Best options seem to be either the matching 75 BB or a Phil BB. Lots of folks seem to use them fine with Shimano with no problems. Would be wary of using them with an ISO taper BB.
https://www.bikeforums.net/singlespeed-fixed-gear/156213-sugino-75-designed-work-shimano-bb.html
fixedpip is offline
Reply
Old 03-16-07 | 06:10 AM
park ranger
Bikes: recumbents
hte MIche bottom brackets come in 110, they are adjustable a bit, they are cheap and they are ISO taper...
edit: and you can get them in italian threading of course.
piwonka is offline
Reply
Old 03-16-07 | 08:17 AM
https://www.bikeforums.net/showthread.php?t=156213
just sayin, on their website they list it as an ISO, a member emailed sugino in the past and they confirmed it's ISO, and i'm getting better results with my ISO BB (crank sits deeper into the taper, symetrical, perfect chainline). which is why i'm trying to say, the sugino 75 may not be JIS as was previously thought/assumed.
Reply
Old 03-16-07 | 08:49 AM
fixedpip's Avatar
asleep at the wheel
Sugino's website does indeed list these cranks as "4-TAPER(ISO)"
https://www.suginoltd.co.jp/track_e.html
They also list the RD2 and Messenger cranks as ISO.
Anyone care to explain as I thought it had been well established that all these tapers were JIS?
fixedpip is offline
Reply
Old 03-16-07 | 08:13 PM
shoot those guys an email / find someone from sugino to contact.
Reply
Old 03-16-07 | 08:48 PM
Retem's Avatar
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
phil wood
Retem is offline
Reply
Old 03-16-07 | 09:04 PM
john_and_off's Avatar
i'm also curious at this point. i had always taken it for granted that the 75's were jis, but businesscycles also lists them as iso, which is surprising to me. i'm somewhat nervous i may be deforming my crank arms if that's the case...
john_and_off is offline
Reply
Old 03-16-07 | 09:33 PM
if it's any incentive, something must have not been matching up on my UN54 spindle because there was already rust on it from just a week use and 1 rain day, i don't know if that's normal, due to improper crank arm installation or because sugino 75's were not made for them.
Reply
