plz help me with trick
Old 08-21-02 | 10:07 PM
20 Anniversary
oh and hey can somebody tell me how to manual cause i have such big troubles in manualing and i would really like to be able to do it sometime k thanx.
crzybikr is offline
Reply
Old 08-21-02 | 10:36 PM
pnj
20 Anniversary
it's just a wheelie but you don't pedal.
first learn how to do a sit down wheelie and use your back brakes to keep from falling over backwards.
then find a very steep hill and , with no speed, get in the wheelie position. have your back brakes on FULL
slowly let your brakes out so you roll forward. figure out where the balance point is.
practice,practice practice.
when i ride anywhere from point A to point B i practice manuals.
just pick a spot in the cement or dirt that you plan to pull up and spot a place in the distance you think you can keep the front end up to.
try, try, try again....
pnj is offline
Reply
Old 08-21-02 | 10:44 PM
20 Anniversary
Hey thanx for telling me how to do a manual but i was also wondering how to do a onefooter k thanx.
crzybikr is offline
Reply
Old 08-22-02 | 06:46 AM
New to bikeforùms.net
20 Anniversary
Ok yea um.....slowly.....very slowly take one foot off the pedal. VOILA! 1 FOOTER!
KleinMp99 is offline
Reply
Old 08-22-02 | 09:08 AM
dirtbikedude's Avatar
Gravity Is Yer Friend
20 Anniversary
From: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
Try, crash,try crash, etc etc etc...
Start on the ground and ride with one foot on one off. Find a small jump and take one foot of when you go off it, just a bit. Then try to get your foot higher and so forth. Then just keep going off bigger jumps doing the same thing. Only lift your foot a few inches or so until you get your ballance and are able to get your foot back on the pedal befor landing. Once you build your confidance then start to lift your foot higher and higher. Also, as you lift your foot you might be tempted to push on your bars to much throughing your bike out from under you, bad, try not to use to much pressure on the bars. The other way to learn, just launch some serious air take your foot off and see what happens and learn from your mistake ( this is the way I prefer ). Good luck.
Slainte
dirtbikedude is offline
Reply
Old 08-22-02 | 10:42 AM
20 Anniversary
Thanx for telling me how to do a onefooter i was wanting to be able to do one for a long time this afternoon i'll have to try it at my jumps k thanx.
crzybikr is offline
Reply
Old 08-22-02 | 10:44 AM
20 Anniversary
Hey u know how u told me how to do a one footer i just don't get something though. once u take the foot off of the pedal wouldn't ur other foot and pedal come down k thanx.
crzybikr is offline
Reply
Old 08-22-02 | 11:19 AM
20 Anniversary
Definitly on the ground it will. In the air you just have to prctice and if they do come down you need to be able to get them back horizontal befor landing. On small jumps it wont be much of a concern but the bigger you go the more important it will be to have the pedals level. Practice.
Slainte
Reply
Old 08-22-02 | 11:35 AM
20 Anniversary
thanx for the help and i will try that ok.
crzybikr is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
