Broke my frame.
Bikes: Benotto track
Broke my frame.
So last night I broke my frame, don't know how, didn't crash. It's a 70's Benotto, Italian one. It broke at the bottom of the seatpost tube where it meets the BB. My question, is it repairable? Where would one take it to get repaired? Its broken all the way through, not just cracked.
When I was a little BMX racer getting free bikes I was so siked to break frames, not so much anymore.
PS NOT STOLEN
Bikes: 57cm NJS Bridgestone
Im not a frame builder, but If the joint failed instead of the tubing, I think that would be much easier to fix.
post pics so we can gawk.
Holy mackeral! I was just eyeing a Benetto in a used bike shop today. Is it the 1600? Pics! I bet it is repairable, but it might cost a pretty penny.
Me talk pretty one day.
Originally Posted by dustinlikewhat
I say loc-tite it!
Here's what you want to do *:
The Eyefloater Home Metal and Composite Repair Technique (TM)
1. Sand around the immediate area surrounding the break and clean the surface.
2. Coat the break with a fine bead of carpenter's glue.
3. Cover the first layer of glue with crazy glue. This will be a load bearing layer of glue, so don't skimp.
4. Over the crazy glue, apply a light dab of blue loctite (make sure it's blue!).
5. "Welding" is simply a marketing ploy. Common household solder can be applied (sparingly) at this point around the break.
5. Wrap break area in duct tape (another load bearing layer, so wrap around 3x).
6. Repaint, and you're done!
- eyefloater
*Holy sweet Jesus am I ever joking. If you're a complete moron, step away from the internet and don't do what I just wrote (this isn't directed at the initial poster).
ambassador of good will
Bikes: many.
Steel is always repairable, it's just a matter of whether it's worth the time and money. Is it a lugged frame?
edit: I'd think you could find a reputable framebuilder in SoCal who can do the repair for you. Do some googling and call around.
Drunken Harmonica Band
Bikes: Windsor, Schwinn Le Tour, Schwinn Varsity
In all seriousness, bring it by a metal shop or welder, it'll cost like 15 bucks and take 10 minutes. Please dont glue or locktight that joint.
Beausage is Beautiful
Bikes: Nabiis Alchemy
Quoted: 20 Post(s)
Liked 13 Times
Yo. Everything I’m doing is linked on What’s up with Dave? but most of note currently is Somewhere in Japan.
Bow$$
Bikes: Surly Instigator '02, Schwinn Traveler fixed conversion, '02 Fuji Track
there's always the bill and ted method, chewing gum!
Guest
Posts: n/a
Quoted: Post(s)
Can't remeber where, but I remember seeing a repaired seat tube, but I think the repair was only about 1/4 of the way down the tube. Is the crack right at the BB or is there a bit of tubing to play with? Depending on how far up the separation is from your BB, a competent framebuilder might be able to braze a sleeve on the crack.
