8 speed shifters?
Shreddin' heaven on his 20"
8 speed shifters?
Pricpoint and jenson don't have any. WHYYYYYYYYYYYYYYYYYYYY!!!! AAAAAAAAAGGGGGGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!
Immoderator
Bikes: Gary Fisher Simple City 8, Litespeed Obed
Originally Posted by Bikeforums
Your rights end where another poster's feelings begin.
Quoted: 427 Post(s)
Liked 699 Times
Here ya go:
https://secure11.nexternal.com/share...products%2Easp
Sorry, looks like, for some reason, it didn't pick up the whole thing, but they do have 8 spd shifters.
Bikes: 2002 Rocky HT
Shimano still makes 8 speed RF+ shifters, if you don't mind them saying Alivio on them. My bike came with them, in the 3 years of riding my bike has seen just about every part has been changed, all except my headset, seat post and shifters. If they didn't work great I would have changed them, I have no complaints with their performance when paired with a SRAM 5.0 cassette, PC-59 chain and XT derailler. Maybe I just don't know what I'm missing.
reddingmountainbiking.com
Bikes: Cannondale Jekyll 3000sl, Cannondale F500
another link
https://www.cambriabike.com/shopexd.asp?id=9253
Yeah.i was recently searching for 8 speed components and had a very hard time. Online shops don't seem to carry 8 speed and if they do it is a very poor selection. Even Ebay doesn't have alot.
TreadHead
Bikes: '95 Klein Pulse, '98 Klein Pulse [Single Speed], Mosh (Gaint) 24" bmx cruiser
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
Or get some classic Suntour Expert 8sp thumb shifters. They are teh hawtness!
https://www.firstflightbikes.com/shifters.htm
because my LBS overcharges, is rude, has a bad selection, and overall is not worth supporting.
How about trying to find a local LBS other than the one that you went too. I know about five LBS and from what I have found out there's always one shop that has a hard part to get in stock. My particular LBS is a low budget Schwinn dealer that cater to the low end crowd. And he stocks up on parts that are old tech.
i have 2 lbs's. one is far away, one sucks. i dont like 27's because its simply too much. 21's are good, 24's pushing it imo. also, i don't want to buy a whole new casette, my casette is fine as it is. and i've heard bad things about 27's.
Originally Posted by never
Such as?
Bikes: Cinelli Unica, BP Stealth, K2 Razorback, Steel Bianchi roadie, Bianchi Super GL, Specialized Stumpjumper, and 3 beach cruisers
Originally Posted by Raiyn
Why not just change the cassette and chain and go 9 speed? It fits on your current hub
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
Originally Posted by revmonkey
because i don't like 27speeds.
BEsides, I am 90% sure you can use 9spd shifters on an 8spd cassette. My gf does it and I have done it in a pinch.
Or buy both https://www.bikeroom.com/Itemdesc.asp?ic=LD8400
Wood Licker
Quoted: 23 Post(s)
Originally Posted by duckliondog
Maybe because he doesn't want to have to buy a new cassette or chain. I know I don't. I run XTR 8-speed with a Ti cassete on one of my bikes. It would bankrupt me to replace that with 9-speed XTR. The old stuff works great. I hope MTB doesn't get up to ten speeds like the roadies have.
Originally Posted by Maelstrom
BEsides, I am 90% sure you can use 9spd shifters on an 8spd cassette.https://www.bikeroom.com/Itemdesc.asp?ic=LD8400
Wood Licker
Quoted: 23 Post(s)
This didn't work for me at all. It shouldn't work in theory either. The spacing between cogs is wider on 8-speed cassettes. The total distance between the largest and smalest cogs is the same, so if you mix and match, you end up shifting part way into some gears. You might as well use old school friction shifters.
Acera (8spd) on lx (9spd) cassette. Theory or not. I have seen and made this work. Obviously you have to limit the deraileur to not go past the 8th gear. But this did work. In fact. It still works on my gf's 2002 Stuff which came with an 8spd cassette and 9spd shifter and has original parts.
You are right in a way, could be a lucky match. But I have seen this work a couple of times. Obviously it isn't the cleanest of shifting, but it does the job I am likely not as picky as some of the more xc oriented riders.
But ya...friction shifters was my next suggestion, that or grip shift
Ah, well, I guess life just isn't fair sometimes. Nor is life. You're right, it does work, just not to the degree I wanted it to. I was able to shift into all of my gears, I just hated the way it did it.
