Losing Muscle, What to do?
The Question Man
Hey guys. I'll ask this question regarding me but I'm sure more people have had or are having similar problems. I've noticed over the past few weeks that (according to my scale) I seem to be losing muscle and "gaining" fat. My body fat % has gone from as low as 8% a few weeks ago to today where it read 12% ! It seems like a lot but I weigh around 135. So my question is what should I (and others with the same problem) do to gain that muscle back? Should I limit my carbs and up my protein? Thanks in advance for the help.
Extreme nutter
Bikes: Scott AFD expert, with some carbon upgrades.
Have you reduced you work load?
12% is very low. Infact alot off body builders struggle to get down to 8% as thats silly low, and could limit you performance on the bike.
Why do you think your lose muscle, and not just putting some fat, on.
The Question Man
Extreme nutter
id say give it a few weeks to get back into you normal routine and see what happens, if theres a diffenant increase then reduce you callories intake. But you should eat 1.5g of protein per every 1kg of body weight.
Plus becareful with the scales, you should eat or drink around 30mins before weighting yourself. Plus try to do it the morning, the only real way to get a fully accurate body fat is with calipers.
heres a little table for you
Fat Level Men (%) Women (%)
Very Low 7-10 14-17
Low 10-13 17-20
Average 13-17 20-27
High 17-25 27-31
Very High above 25 above 31
Very Low 7-10 14-17
Low 10-13 17-20
Average 13-17 20-27
High 17-25 27-31
First, Body fat scales are not all that accurate, but that being said. If you are loosing weight and not working to grow muscles, you most likely are canibalizing your muscles at the expense of weight loss. I would suggest that you start, or increase the amount of weights you are lifting. You need to retain muscle or you will loose muscle and fat equally. And as you get to that low of a number, your body will not want to give up any fat.
Originally Posted by cheebahmunkey
...So my question is what should I (and others with the same problem) do to gain that muscle back? Should I limit my carbs and up my protein? ...
However, cutting back on carbs WILL cause muscle catabolism (disassembly) if you're working out hard. That's because carbs are the most favored energy-source, then protein, then fats. So if you're low on carbs when you work out, your body will take apart perfectly good muscle to burn for energy at the same time as fats. The most fat you'll burn is about 300 calories/hour, so if you work out harder than that, you'll need to supplement those calories from fat. If you don't have carbs available, your body will take apart muscles to burn.
Also the dunk-test is really the only accurate way of measuring body-fat. Changes in water-retention will throw off the pinch-test or the electrical-impedance test.
The Question Man
Well the thing is I don't work out very regularly because of my school schedule. If I'm lucky I can do a 30 mile ride three times a week. And I haven't been lifting at all either. The only other pure "exercise" I've been doing has been 200 crunches every day. I'm not too worried about it but I'd like ot see my % go back down. I fear I was overcompensating for eating so much and actually started to eat away at muscle by not eating enough afterwards. But you guys have good suggestions. I know I'll keep them in mind. Thanks again.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
Be sure to have plenty of fuel in the tank for your bike rides and eat soon after you finish so your body burns carbs/fat and not muscle.
When you ride, are you pushing your heart rate to the max? Better to stay in the 60-70% heart rate max range for fat burning.
Dual energy x-ray absorptiometry (DEXA) scans are highly accurate for measuring % body fat. Also very expensive.
If you're losing muscle, like your body composition is actually changing (you're not just experiencing gained/lost water weight or daily fluctuations) then a good way to slow/prevent catabolism (muscle breakdown) is to A: increase your daily caloric intake and B: increase the percentage/quantity of protein in your diet.
Bikes: Too many to list!
Do this once/week, and use the numbers for comparison sake only.
