9/10 speed wheel diff from 8 speed wheel?
Is the 9/10 speed cassette the same width as an 8 speed - just closer spaced?
...or is a wheel for 9/10 speed built differently - wider hub and dished more to accomodate it?
( I have several sets of 8 speed wheels/cassettes, just want to use newer Ultegra shifters)
Thanks.
Thanks.
Liked 7 Times
There is a difference but the 8-speed hubs will work with 10-speed cassettes. Use the spacer behind the cassette provided with the new cassette(s). Of course you will need 10-speed shifters, and chain also.
Al
Al
Quoted: 7 Post(s)
Al
Al
Is this true with Campy hubs too? I thought they were not compatable.
Liked 7 Times
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
9-/10-speed hubs will accept 8-speed cassettes if for some bizarre reason you wanted to do that.
Theoretically you can upgrade an 8-speed hub by replacing the body, but in practice you can't get the parts.
Sheldon "Shimano Hubs, Campagnolo Shifters" Brown
Code:
+---------------------------------------------------------------------+ | A man of character finds a special attractiveness in difficulty, | | since it is only by coming to grips with difficulty | | that he can realize his potentialities. -- Charles DeGaulle | +---------------------------------------------------------------------+
Quoted: 7 Post(s)
Year-round cyclist
Look at https://sheldonbrown.com/k7.html.
With a Shimano system, your 8-speed wheels have the same hub that will work with 9 or 10 gears. There are two catches:
1. (See the link above). Your present freehub may or may not accept an 11-teeth first cog. If it doesn't, I don't know if a 10-speed cassette would fit; however, you could replace the freehub core with a compact core for about 20 $.
2. Even though the freehub is the same,
a 08-speed cassette is 35,4 mm wide
a 09-speed cassette is 36,5 mm wide
a 10-speed cassette is 37,15 mm wide.
Sometimes, the right seatstay may be a wee bit too close to the small cog.
On the other hand, if you decide to buy new wheels, the new Dura Ace 10-speed wheels have a freehub design which is not compatible with 8 or 9 speed cassettes.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
No, it is not true with Campagnolo. 8-speed Campagnolo hubs ony take 8-speed cassettes.
Code:
Thanks all!
As I've said, I'm going to be using Shimano 9 speed stuff for everything - shifters , cassette, chain - just wanted to be able to use my old wheels. Cassette is probably going to be 12-21/23, so from the responses I don't think I'll need to struggle with an 11 cog.
Thanks again.
Thanks again.
Liked 7 Times
Originally Posted by rufvelo
Thanks all!
Thanks again.
Thanks again.
Al
Liked 7 Times
Actually, I was thinking of upgrading from an 8-speed system to 10 gradually. Just buying the wheels first would be a good start.
Al
Quoted: 7 Post(s)
The problem with "gradually" is that you have to change the shifters, cassette, and chain at the same time. And basically that's all you need anyway.
Al
Al
Year-round cyclist
I have the 10 FD on the bike. ....
The front derailleur is already 8, 9 and 10-speed compatible. In other words, Shimano called it an 8-speed FD when they offered 8-speed gearing; they called it a 9-speed FD when they offered 9-speed gearing and they now call it 10-speed FD nowadays. But it's the same.
Quoted: 7 Post(s)
semifreddo amartuerer
Bikes: several
crusty
Bikes: Giant Kronos, Miele Appolo, Miele 12 spd, Diamondback Hybrid
The Ultegra FD is designed to be used with the Ultegra brifter which has a superior trim function built into it. If you used the Sora brifter you wouldn't have had that option, hence the rubbing.
Bikes: several
