Measuring a Frame - TT hitting the jewels
Bikes: Bob Jackson Track, 1985 Centurion Dave Scott, 1983 Miyata 610
Hello. Just had a quick question about how to accurately measure a frame's height? Do I start from the middle of the bottom bracket and then take it all the way up to the top of the tob tube? I thought I was a 53cm frame since I'm around 5'8" with normal inseam, but the top tube of the frame I have is digging into my jewels (no clearance at all) and so I'm wondering if I need a smaller frame or if the frame is not actually a 53cm. I was told a good 1-2 inch clearance from the tt to the groin is standard. Is clearance really not important?
if you plan on never standing over your bike then its not important. you could manage if you track stand all the time and hop onto and off of your bike while still in the pedals.
it sounds like you've got 53cm stuck in your head. if it doesn't clear your balls, i think its too big for you regardless of what size you 'should' be. bikes are either measured center to center or center to top. the first being the bottom bracket and the second being at the place where the top tube connects with the seat tube. but that doesn't account for how high the bottom bracket is from the ground.
Guest
yep clearence is important, jump off the bike and on the toptube while the bike's in motion . there is your answer.
there is no normal inseam. the rule or say in the rule is take a stick place between your legs up to the crotch level measure from the top to the ground.
yes 1 to 2 inch rule does apply if you cannot do the above. maybe Don Walker will chime in later.
S/F,
CEYA!
S/F,
CEYA!
Retrogrouch in Training
Measure center to center from the BB shell to the top tube. If this is a track bike, you may very well have a 53cm frame but with a higher-than-road bottom bracket. I'm 5' 8" (with a 31.5" inseam) on a 54cm bike and not only does the TT hit the jewels, it actually digs a little into my pubic bone.
In practice it's not a problem other than having to swing my leg over a little higher. The rest of the time, I can just tilt it off to the side to get it a little lower while just standing around. I don't know about you, but I don't spend a lot of time with my feet on the ground when I'm riding.
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Originally Posted by baxtefer
standover is overrated.
is the TT the right length?
Al
Arizona Dessert
Liked 2,169 Times
^ yeah, and who rides barefoot?
Thats why I said barefoot, to eliminate the sole part of the equation.
Al
Cornucopia of Awesomeness
yes yes I understand
i was just trying to reinforce your point.
my commuter is "too big" for me. it's a 62cm c-c traditional geometry frame. I have short legs for my height, so for satndover, i should really be riding a 57. Unfortunately a 57 would have waaaaaay to short a reach.
I have 0 standover barefoot. and mabye 1cm or so with shoes on.
I have yet to sack myself with the TT.
72 & Sunny
Bikes: '93 Yamaguchi Pursuit track bike, Alan Super Record
This is good to hear, as I just bought a frame that's a bit taller than my others and I was somewhat worried.
72 & Sunny
But I'm bullheaded. I'd just ride in very tall shoes.
[/hijack]
[/hijack]
Arizona Dessert
Liked 2,169 Times
Al
