how much air to pump into a rockshox mag21?
Quoted: 430 Post(s)
Liked 460 Times
as topic says, any advices appreciated, thanks.
Quoted: 430 Post(s)
Liked 460 Times
there is a hole to pump air into to build up the pressure. the mag21 was an oil fork (whatever that means???) but you could put air into it to adjust dampening.
Liked 6 Times
The Mag21 is an oil-damped, air-sprung fork. It typically takes 40-60 psi depending on your weight. I weigh about 165 pounds and typically used 40-45 psi. Because the legs have negative springs to cushion the top-out, the fork will be missing some of its stroke if you underpressurize it. Heh... I believe I still have a pair of the long-travel spacers hanging around for the Mag21, too. Quite a fork... it was my first suspension fork and I really enjoyed mine.
