Grips over cables
Grips over cables
Hey all,
Has anyone slid a grip over a brake cable? I would like to have some mountain bike grips, oury's for example, near the stem on my bullhorns since I usually ride up there, but I am not sure if I'll be able to get one to slide over the cable.
thanks,
C
thanks,
C
i am sure that i hate you
Bikes: 'Cha-ruzu Fosuta Orusan Kein' Fuji Track (2005), Schwinn Tank MTB (?), Fuji Royale (1979)
Originally Posted by 3niktac
Hey all,
thanks,
C
thanks,
C
putting the pi back in pirate!
It’s an upstanding member of the solar system
Apply the laws of earth and make it a victim
Of Proposition 187
Of Proposition 187
Pain Cleanseth
Bikes: On*One Imbred (commuter), Specialized Rockcombo(commuter)
Shouldn't be a problem, just use some rubbing alcohol to lube things up.
Originally Posted by spud
picture?
I have bullhorns (the nashbar ones to be specifc) and want to put grips near the stem with the brake cable routed under the grip. I'm wonderin' if anyone has successfully done this.
C
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
Quoted: 80 Post(s)
Liked 14 Times
Or cut a slit out of the grips for the cable and gorilla glue the grips on. That way you don't have to jam them on. much easier.
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
I think you misunderstood me.
C
C
ok, i did i was just trying to get a picture (or some reference to your current setup) to try to envision how much cable you have to work with and the chance of a pinch or kink being an issue...on to look at nashbar bars...
Of Proposition 187
Of Proposition 187
ok good, i got sidetracked looking at the shoe sale
Of Proposition 187
Of Proposition 187
C
ok, i think you should be fine. reglue as needed if youre going to go that route.
Of Proposition 187
Of Proposition 187
Cornucopia of Awesomeness
you're going to have to mount the grips before the brakes.
and slide the houseing under the grip.
that doesn't sound like too much fun.
Bow$$
Bikes: Surly Instigator '02, Schwinn Traveler fixed conversion, '02 Fuji Track
woah woah woah! did some one say SHOE SALE**********?? LET'S GO GIRLS!!!
Not only does it not sound like fun, it doesn't sound possible to shove the housing through after the grip is mounted.
C
C
Dances a jig.
Bikes: 2007 Surly Long Haul Trucker 54cm (Commuting/Wanna' go tour so bad), 1985 Trek 670 21" (Road), 2003 Gary Fisher Tassajara 17" (MTB), Cannondale DeltaV 600 (commuterized MTB), some junker bikes in my garage
It might work doing it this way:
Put the grip on the bar first, without the cable under it.
Work a screwdriver under the grip all of the way working from the opposite end the cable needs to start at.
While pushing the cable in one side, pull the screwdriver out the other.
The screwdriver basically lifts the grip up to create a tunnel for the cable to pass through. You'll definately have to lube everything up with some rubbing alcohol, maybe even WD-40.
Warning, I have no idea if this will work or not, just a theory.
645f44
It should be possible to shove the cable through after the grip is mounted. Just use plenty of wd40 and get the grip loose on the bar first. Probably best to choose a nice stretchy grip and avoid the duel compound type that have a harder core and soft outer.
I don't know how well it will stand up to rain. There will be air gaps around the cable which could allow water to get between the bar and grip.
Foward Leaning Attitude
lots of hairspray for lube ... when it drys it holds the grip in place. Oury grips are fairly soft and flexible so lube the crap out of the grip slide it to where you want it, lube up the housing with the HP and jam it through then rinse the excess HP off the grip and you should be all set. Water could be an issue, it might break down the HP over time which coould cause the grip to move around a little ... run the cable on the back side and you should be all set. note: use lots of hairspray it get tacky quick.
Bikes: a tvt soon to become a s/s...
if you feel like using a walnut to crack a sledgehammer:
get a metal skewer and heat it over a gas flame.
them press it on the inside of the grip [but not too hard] so that the grip melts and you get a semi-circular indentation on the inside edge of it.
or: put the grips in the oven at about 50degrees C [until they're just a little pliable. not melty].
don't blame me if you fu<k it up though. rubbing alcohol and hairspray sounds like a much better idea.
fsnl
sparky
fsnl
sparky
ok its settled, the DC Street Pirates will save you (The Burrito Bandits) the emotional trauma of getting pwned in actual biking competitions and will procede to kick ass in the Barbie Shopping Spree card game, that way we can play inside Chipotles and you can buy us burritos and beer.
Of Proposition 187
Of Proposition 187
Radio Bemba 00.0
Umm. I have done this. It is not complicated. Just requires a little bit of elbow grease. I used windex (or the generic equivalent thereof, rather). Lots of windex. it worked great. A twisty motion will serve you well, too. (PS- done with Oury grips over a break cable on track drops.. you can do it!)
