Spoke Prep Vs. Grease
Bike H4><0R
Ok looking at Spoke prep. is there any reason to use this stuff over linseed oil or Marine Grease?
Carpet smoking check on isle one please.
Quoted: 114 Post(s)
Liked 119 Times
My bike's better than me!
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
Allow me to bless you with the benefit of my expertise:
Preparation
Spoke threads and spoke holes in the rim should generally be lubricated with light grease or oil to allow the nipples to turn freely enough to get the spokes really tight. This is less important than it used to be due to the higher quality of modern spokes, nipples and rims, but it is still a good practice. In the case of derailer rear wheels, only the right side spokes and spoke holes need to be lubricated. The left side spokes will be loose enough that it will not be hard to turn the nipples even dry, and if you grease them they may loosen up of their own accord on the road.[1]
[1] https://sheldonbrown.com/wheelbuild.html
Preparation
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I don't like spoke prep because it makes the nipples difficult to turn. This makes building the wheel a real pain, particularly if you are using thin spokes which will wind-up a lot. The nipple locking feature of spoke prep can be an advantage however if you are building a low spoke count wheel since each spoke/nipple is highly loaded which leads to a high variation in tension as the wheel roatates under the rider (which can cause nipples to loosen).
Originally Posted by neil0502
Spoke threads and spoke holes in the rim should generally be lubricated with light grease or oil to allow the nipples to turn freely enough to get the spokes really tight. This is less important than it used to be ... only the right side spokes and spoke holes need to be lubricated...
3 in 1 has probably changed formulas, but it used to be vegetable based and subject to getting gummy and useless from oxidation, so it should never be used on anything that you expect to continue to function for more than a few weeks.
Year-round cyclist
I can't remember where I read it, but Spoke Prep and Linseed oil (the latter recommended by Peter White if I remember correctly) lubricate the threads at first but eventually become grabby. That way, tensioning is easy, but the wheels should stay true for a longer time.
In practice, I use grease because my wheels are used under all weather. I want to be able to readjust the spokes if and when needed 3-4 years down the road.
