Where to clamp bike with a repair stand?
I have a new Orbea Onix bike. It is all carbon and I have a carbon seat post. I am concerned about where to clamp onto the bike with a repair stand. I am worried about damaging the frame or the seat post. What is the best and safest way to clamp a bike? I have even thought about making my own stand that would the top tube would rest on both at the front and the back. Am I just being paranoid or do I have to be extra carefull?
Thanks
Thanks
Senile Member
If you're very very paranoid, do like I do with my bents: hang it to the ceiling with a soft cotton rope by the bar ends and by the saddle. Sure it'll be wobbly to work on it, but at least you'll be extra sure it won't be damaged.
My bike's better than me!
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
You are being paranoid, but correctly paranoid.
Never clamp your bike by its tubes. Don't clamp it by its CF seatpost, either.
Buy the cheapest seatpost that will fit your seat tube and use it as a "build post." Clamp your bike by that build post.
Works every time. Prolly find something for ten bucks. Cheaper than either a new frame or a new CF post....
EDIT: Here. Three bucks in 31.6mm dia. Prolly something for not much more on the same site if yours is of a different diameter: https://www.jensonusa.com/store/produ...e.aspx?sc=frgl
Senile Member
Quoted: 2026 Post(s)
Liked 1,096 Times
Originally Posted by ppc
Is that common practice? I've never owned a carbon bike, but I can't see why a carbon seat post wouldn't stand the torque of the bike being lifted by it. After all, it can surely withstand the weight of the rider pushing backward or something.
The recommendation to buy the cheapest proper diameter seat post you can find and use it with the repair stand is a very good one.
what about for simple adjustments and cleanings? The bike is allready built (I did it without a stand) I just want to be able to do a better and easier job at adjusting the derailures as the cables strtch and make other adjustments.
Bikes: Trek, Cannondale Tandem, Surly LHT
I agree, clamp on the seat post. I disagree that a cf seat post is too fragile. I was at my LBS the other day and they told me they just prepared a new Cervelo for Dave Zabriski and I know their "world class" mechanics clamp on cf posts all the time. These guys are top shelf mechanics and prepare bikes for guys like Zabiski, Levi Leipheimer, etc. BTW, they are the largest Orbea seller in the U.S.
The seat tube clamp exerts a lot more concentrated pressure on the post than a repair stand ever would. You won't crush it with a repair stand clamp. If you're concerned about protecting the finish, go ahead and put a rag around it. My stand (Ultimate) has nice soft jaws, so I don't bother. Have clamped my and my wife's Bontrager Race X Light cf post all the time and no marks, no problems.
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
I noticed that my LBS clamped my (freshly painted) fixed gear conversion by a seat-post-surrogate. I appreciated their consideration!
This one's pret-ty simple, folks: clamping to anything other than a build post (or the expensive equivalent sold by Park Tool) = some risk, no reward.
You can do what you want with your bikes. I'll continue to use the low-$ seatpost with mine. Takes about six extra seconds. Takes risk down to zero.
Don't mean to sound like my answer's the only one worth beans here. It's far from that. But I don't take chances with expensive frames or expensive components. Not sure why anybody would. As to Dave Zabriski, incidentally, if something does happen to his seatpost (or any other piece), they run to the van and grab another one off the shelf. It's not always fair to try to translate what team wrenches do into what you or I should do.
Just my $0.02. YMMV.
Bikes: 8 bikes - one for each day of the week!
Originally Posted by HillRider
It's not the axial load of lifting the bike (or supporting you) that's the problem. It's the radial load from the repair stand's clamp. Frame tubes and carbon seatposts don't have a large amount of "crush" strength since that's not what they are designed for.
Liked 1,096 Times
Originally Posted by Expatriate
You couldn't crush a CF post with a bike repair stand. The concern would be that the bike not get bumped around while being held by a CF post.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
If you're still looking for a repair stand, look into the types that don't have a clamp. Minoura and Park have repair stands that cradle the bottom bracket and clamp the fork.
Park version.
Minoura version.
Park version.
Minoura version.
The CF seat post cannot tolerate much in the way of bending. Apparently, one of the guys in The Aussie Thread just busted one. He avoided a core sample though.
blithering idiot
Bikes: 1991 Trek 930, 2005 Bianchi Eros, 2006 Nashbar "X," IRO Rob Roy
Originally Posted by jhota
i'm a fan of these:
As a point of interest, Trek uses a standard Race c/f seat post on the captain's seat. Go here if you're interested: https://www2.trekbikes.com/bikes/bike...d=1492000&f=11 The stoker's stem and handle bars are attached to this seat post, usually quite a way up on the post. That's a lot of side load and clamping force, too. Certainly, if you're at all concerned about clamping on your Orbea's post, do as suggested. It's always a good idea to error on the side of caution, but I strongly doubt you'd be able to hurt it, even if you tried! Just my $.02 and worth every penny...
We agree on the notion that a build post simply provides an "abundance of caution."
