Bent Skewer on Road bike
Old 11-01-05 | 08:42 PM
ginger green's Avatar
Good Enough
Bikes: gary fisher mtb - Bridgestone road
Hi Everyone:
I have discovered that my front skewer is slightly bent. I don't know how. Is this common or fatal? Are the skewers from nashbar a good alternative to spending 40 on a name brand pair?
GG
ginger green is offline
Reply
Old 11-01-05 | 09:20 PM
supcom's Avatar
You need a new bike
20 Anniversary
When you tighten the skewer, you put the rod in tension, which should straighten it out. If it doesn't show any particular signs of damage or major corrosion and it is still working, then it should be good to use.
supcom is offline
Reply
Old 11-01-05 | 11:23 PM
Brian's Avatar
Bikes: 8 bikes - one for each day of the week!
You need to first figure out why it bent. Nearly any old skewer will work in it's place, so how much you spend is up to you. Nashbar ones would be fine, as in most cases, spending more money only gets you less weight. Keep in mind that it does keep your wheel on.
Brian is offline
Reply
Old 11-01-05 | 11:57 PM
MudPie's Avatar
20 Anniversary
Originally Posted by ginger green
Hi Everyone:
GG
I am curious - can you describe the bend? For example, is the entire skewer bowed in a gentle curve or is only the end bent. I assume you can remove the skewer from the axle.
The skewer itelf only experiences a pure tension force when it's in service. I should not experiece any other forces which could cause it to bend.
MudPie is offline
Reply
Old 11-02-05 | 12:14 AM
RockyMtnMerlin's Avatar
Bikes: Merlin Extralight Topolino Wheels Campy Record
Expatriate gave the correct anwser. Unless you are concerned about a a couple of ounces get a cheap one, throw the bent one away and ride on!!
RockyMtnMerlin is offline
Reply
Old 11-02-05 | 12:33 AM
Brian's Avatar
I took an extra smarty pill this morning.
Brian is offline
Reply
Old 11-02-05 | 07:00 PM
Good Enough
I was scratching my head too as to how it was bent. The bike is second hand 2001 - overall in good condition, no obvious crash signs. The skewer is straight until you get to the threads where it makes a little tight bend. Normally I would not hesitate to straighten such a simple bend, but there is no way I'm going to experiment on my front skewer.
I will probably replace the skewers any how. I don't think you can have a minor when your front skewer fails. LOL
Reply
Old 11-02-05 | 10:35 PM
Bikes: '13 Felt Z5, '13 Giant Anthem 29er, '05 Specialized Sirrus, 2021 Fairdale Taj, 2021 Surly Midnight Special, 2022 Surly Midnight Special
I had a rear wheel that kept falling off, the problem was a skewer that had a slight bend at the threads. The bend didn't allow the skewer to tighten properly (evenly) on the dropouts.
Adam
ArizonaAdam is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
