Putting holes in bullhorns
Old 11-14-05, 12:26 PM
Old enough to know better
Spudmeister's Avatar
Bikes: On One, Surly, Gunnar, Lemond
I've scored a Syntace Brake Lever for my bullhorns a few weeks ago. They are designed to run the brake cable inside the handlebars, so I need an exit hole. In the past I've seen handlebars that have been drilled for internal routing - often done by the owner, not the manufacturer. I already know that Syntace makes bars for this lever, but I'd like to avoid spending more money.
Anyone out there drilled a hole in their handlebars for themselves? How bad an idea is this? Where would be the best spot on the bars to put a hole?
Any constructive advice would be welcome.
Spudmeister is offline
Old 11-14-05, 12:38 PM
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
right out the other end!!!!
just kidding.
it would have to be more than a hole. more like an oval, so that it's not hitting a sharp bend when you make it exit...
queerpunk is offline
Old 11-14-05, 01:52 PM
meet the mets
chicagoamdream's Avatar
Bikes: Raleigh conversion (hours spent making it look like a Pista); Porter Track, Samson Track, Leto Roadie.
I know you said you don't want to spend any more money, but the Syntace 'horns are only $12.50 on Chuck's. I bet you could sell whatever bars you have now for that on eBay or CL, thereby breaking even. These bars not only have holes but little impressed tracks for the cables, which'll make everything lie flatter under tape.
I don't think a regular drill/bit could do a clean enough job, and I would imagine that most other options will total more than $13.
https://www.chucksbikes.com/store/indexbr001s.htm
chicagoamdream is offline
Old 11-14-05, 02:00 PM
King Among Runaways
hyperRevue's Avatar
Bikes: 2004 Bianchi Pista, Cannondale Track, Soma Pake, Schwinn Breeze
Can't you just run the cable under the bar tape?
hyperRevue is offline
Old 11-14-05, 02:15 PM
No, they're designed to run through the bar. The cable leaves the lever through the wedge that goes inside the handlebars.
Old 11-14-05, 02:17 PM
That's a good suggestion, but I like wide bars. Syntace are only available up to 42cm (44cm outside).
Old 11-14-05, 02:57 PM
'possum killer
chuckfox's Avatar
Bikes: mountain bike (Litespeed Pisgah), touring bike (Giant Frankenbike), tandem (Burley Samba), fixie (Raleigh Rush Hour)
Liked 8 Times in 1 Post
The "Profile Stoker 26" bar that I use has two holes, one closer to the end of the bull bar on the lateral side, and one closer to the bend on the medial side. My aero lever starts the cable on the lateral side of the bar then the cable goes through the bar to the inside side. The cable then goes under the tape to near the stem. The holes are beveled to accomodate the cable housing going in the direction of the bar. I would think you could drill a hole the size of the o.d. of the cable housing, then stick a rod into it (something close to the cable diameter) and bend the hole so it's angled to better match the cable direction.
Now Wheaties are cheaper than gasoline!
chuckfox is offline
Old 11-14-05, 03:11 PM
LF for the accentdeprived
We should swap levers... I have Cane Creeks on a Ritchey 'horn. The cables exit the lever on the outside and the bars have imressed channels for the cables only from halfway; meant to be drilled at the exit, so internal would suit me better.
The drilling itself isn't a big deal: make a small hole w/ a drill bit, then ovalize it with a small round file, making sure you leave no sharp edges.
On a bar like that, I'd probably do it on the outer area of the straight section, that is, as far as possible from the stem. This way the hole weakens the tube where there isn't that much stress. I wouldn't be comfortable at all riding a bar that's drilled close to the stem. If you drill just after the bar turns in towards the stem, you get a less sharp curve in the housing, but don't weaken the bar too much.
LóFarkas is offline
Old 11-14-05, 03:16 PM
Rebel Thousandaire
Ya Tu Sabes's Avatar
Bikes: Public D8, Yuba Mundo (cargo), Novara Buzz (1-speed, soon to be 2-speed w/ a kickback hub), Xootr 1-speed folder
I once had a bar that was a little too narrow in diameter for the stem I wanted to use, and I drilled a hole through the bar and the stem and but a bolt through to hold everything in place. Despite warnings about catastrophic failure, the set-up held up for nearly a year (it didn't break; I just wanted a different bar set-up). Drill away, it'll probably be fine.
Ya Tu Sabes is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
