Can you make a triple into a double?
I have a Trek 1000 with the Sora drive train. Could I just take the granny gear off and adjust the front derailleur?
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Or just leave it there and don't use it...
Yes you can do it, but your chain line will not be quite as perfect as if you went to a true double. Plus your second chain ring might be a bit larger than if you had a traditional double, so your low gears won't be as low as they might be.
Just out of curiosity, what do you hope to accomplish?
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Quoted: 2026 Post(s)
Liked 1,096 Times
1. Remove crank fixing bolt
2. Remove drive side crank arm
3.. Remove granny ring.
4. Adjust inner stop on front derailleur
5. Save 30 grams.
5. Save 30 grams.
Quoted: 128 Post(s)
Liked 12 Times
Yeah, you should get a new bottom bracket so the crank will be closer to the centerline of the bike. Maybe 5mm shorter bottom bracket?
If you like this and it keeps you busy, have at it. But saving weight is not a meaningful reason to do this, especially given that you're riding a Sora-equipped bike.
Well, 5mm shorter on the right side. This moves the center between the two chainrings roughly into the position of the earlier middle-ring and lines it up in the middle of the cogs in the rear. However, to preserve even pedal-distance from the bike's centerline, you'll have to shorten the left side as well. So 10mm total. It's typically between 8-12mm depending upon how optimal the original chainline was with the triple.
Due to the angular swing of the FD, you'll need to raise it up about 2-3mm as well.
Emondafied
Bikes: See sig
Quoted: 63 Post(s)
Then take a dump and save twice as much as the parts you removed weigh.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Use one water bottle instead of two and save big weight.
I see where you're going and we've all been there. Don't spend big bucks (or any bucks), just ditch the granny ring and adjust the FD. Any expense will not gain you anything. Now if you wanted to really do it right you'd need a rear der, new cranks, new BB ..... more than it's worth. Better suggestion, just don't shift into your granny and don't look down (you'll never know you're riding a triple!!!
Whenever anyone posts a "I want to convert my triple to a double" question, several people suggest that it is a useless endeavor. After moving from the mtns to the plains, my triple's smallest chainring was totally useless, so for a total of $260 (I shopped very carefully) I converted to a double -- new crankset, BB, FD, RD. My drivetrain is now marginally lighter, has a slightly better Q-factor, and there is far less chain rub than before, and that's worth the money, to me. So if you want to do it, Equinox, I say go ahead.
Bikes: Salsa Casseroll w/ 10 speed SRAM, Origon8 SS, Bianchi Parco 3speed
Originally Posted by Equinox
I just wanted to have a little fun and feel like an amateur wrench.
It may not be cost effective to do it, but learning new skills and having a little fun with it, makes up for that.
That is just the way I look at it.
Mike
