Effect of Cold Weather on the Bike???
I'm in the Northeast and it's finally getting colder. I see a lot of posts about clothing and nutrition in cold weather but not about care of the bike. In terms of maintenance, should any special precautions be done to keep the bike in shape? Does the cold have an effect on cable strength or make cables, spokes or other parts more brittle? Is there a need for extra lube...etc.? Any thoughts would be appreciated. Thank you.
Bikes: Salsa Casseroll w/ 10 speed SRAM, Origon8 SS, Bianchi Parco 3speed
The important thing is to make sure you get all the salt off of the bike if riding in areas that salt the roadways.
Take extra care to dry the bike after every ride and keep the chain cleaned and lubed.
depends on the type of bike and how much use it actually gets too
my workbike is lucky to cleaned once a year, I rarely do anything to it, lubing the chain alot or making a big deal about it has become pointless, it gets replaced 2-3 times a year, and I ride where they salt ALOT, they even salted today and all we got was a dusting of snow
singlespeed and fixed gear bikes dont need much maintenance
with geared bikes clean and lubed pivot points on the brakes are a very good idea, keeping the cable routing clean and taken care of is good too or you wont be shifting at all once it gets real cold and wet
if your derailer cable housing is exposed to spray it will get gunked up and need cleaned periodically--------where it connects to the derailer
both mountain bike and road bike brakes will eat your rims in the salty conditions quickly, typical road race brake pads are good for about 10 days of messenger use in the salt
the cold itself wont hurt the bike at all, makes the bottom bracket a little tougher to spin from friction but thats minor
Salt getting in the rims will corrode the rims and spokes a bit, but thats a slow process. I go thru a new rim about every 8 months on the front of my singlespeed just from it getting eaten away by the brake.
Fenders help keep alot of the crap off the bike but the spray from passing cars and trucks still gets all over everything.
Dont know how bad the weather affects shifters or brifters, just know that when its truly cold and wet, most bikes wont shift gears at all after a few hours, and the brakes will be worthless in heavy rain unless youve got disks. Ive had icicles all over my bike before and ive seen brakes freeze up solid.
one very inportant hint if you commute and lock up outside, lube your lock, coming out to a frozen lock that wont open is a real bummer
Around here they do not use salt but instead use mag chloride to raise the freezing point of the roads.
Does anyone know how magnesium chloride affects bikes?
8speed DinoSORAs
In very cold weather (yesterday and today being well below freezing) I had trouble with the freewheel mechanism on my Ultegra freehub. It would fail to engage at odd intervals, leaving me spinning away... or a half-engagement that would "let go" under increased pedal force.
Ages ago, I saw an article on the web about "winterising" a bike. Specific attention was paid to use of a low viscosity lube for the freewheel to avoid the problem described above. Basically it involved removing the freehub, taking out the rubber seal, flushing old lubricant with solvent/WD40, allowing this to dry and introducing a low viscosity oil.
Cheers,
Ed
Cheers
Cheers,
Ed
Cheers
Get a bicycle. You will certainly not regret it, if you live.
custom user title
as said before, it`s not the cold as much as the salt... i, like many other people here, have a dedicated winter bike. (i buy used bikes and winterize them (wheel, fenders, ...). i use them for a couple years and change it (i park it in a overheated garage at the job and it rusts). i just changed it this year...
and yes, at very cold temp things do not work as well and need more lub. i mean, under -20C. otherwise, regular maintenance is good enough!
Dog is my copilot.
Bikes: Lemond Maillot Jaune, Specialized Stumpjumper, Kona Jake the Snake, Single-Speed Rigid Rocky Mtn Equipe, Soon-to-be fixed Bianchi Brava
Going below -20c its not the amount of lube, but the type, and unless your willing to repack bearings (if they're not sealed cartridge) everytime it gets cold you just have to grin and bear it.
