Hey! a2psyklnut. Please explain this...
Jubalayo Unogwaja!
You mentioned somewhere else a couple of times, that Cannondale's Lefty is a strut and not a fork, so it has in common with aircraft landing wheels. Can you explain what the differences are between them?
I mean, both compress when you push on them. They both rebound, and both make nice squishy noises. The differences are where, in the design, function, engineering?
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
Doesn't a fork have to... well... fork? That is, I would assume a fork need to have two blades, at least, no?
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
Jubalayo Unogwaja!
That's what I thought, though I think he did mention once before that the difference is other than having two alone?
Bikes: Lots
Correct, a Fork has two blades a strut is single sided. Simple as that!
There was a strut in the BMX circles that came out a bunch of years ago that just wasn't successful. The design was rigid and I guess it couldn't handle the stresses imposed by BMX.
I was super skeptical when the LEFTY came out. I thought that it would be weak and easily destroyed. I was wrong. The R&D at Cannondale did their job very well. I used mine for 2 years and had 0 problems with the Lefty. I'm not featherweight either.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Jubalayo Unogwaja!
A strut it is, then!
Are there any other internal differences that distinguish it from a a conventional fork? I know there are different forks and RockShox and Zocchi, for example, probably have similar-ish internal designs, but does a strut need anything radical doing to it that a conventional fork does not require?
Glad to hear you have positive feedback about the Lefty. I notice it will now be offered as a standard option on the new 2003 Geminis?
Bikes: Lots
Cannondale has partnered up with Manitou to help design the internals for the new LEFTY's. Haven't seen any details yet, just that they're now working together.
I didn't know that Lefty's were being offered on the new Gemini's. Where did you hear that? I just spoke with C'Dale last week and got the latest specs for the 2003 bikes and the Gemini spec was nearly identical to the 2002. Paint scheme's are different. They're coming out with a "Team Replica" and a "Real Tree - Camoflague" (sp?)
Maybe the European models are different???:confused:
L8R
L8R
Jubalayo Unogwaja!
I'm looking at a supplement that came in the UK magazine MBR. It describes what's new for 2003.
One page 8 is dedicated to a number of photos for what Cannondale is unveiling. They have a photo of the headtube and a bit of the Gemini decals.
The comment they have is: "All bikes are now 1.5in fork ready, and there's now an additional Gemini available with 'Lefty Max' spec."
They also have a singlespeed hardtail called the Optimo.
What interests me as well, is that the sh1t-awful rear lock-out lever that my Gemini came fitted with (Shimano) is now replaced with what the lbs told me a while back, was a Cannondale in-house design. It looks much nicer and could be less obtrusive and easier to use. My baby goes in for a service tomorrow, so I'll find out if they can upgrade me.
Bikes: Lots
Hey Bokkie you are absolutely correct. Here's a link I just got https://www.cannondale.com/bikes/03/cusa/model-3VG1.html or if you want the details on the MAX: https://www.cannondale.com/bikes/inno...ftymaxtpc.html
I'm still debating whether or not I need this much bike.
L8R
L8R
Jubalayo Unogwaja!
Go for it. Be the best you can.
