Best protectant for rust prevention?
Whats the best stuff to use to prevent rust on bike parts (exposed cables, cable fittings, small steel components, etc.).
WD40? Armorall? Motor oil?
And how often should everything be wiped down, assuming some kind of protectant is used? I usually ride near the ocean, so the bike is somewhat exposed to salt air. All of my other bikes look like crap, but I'd like to keep my new bike looking good.
For a carbon fiber frame, is car wax recommended?
Keep a vat of cheap olive oil on hand to dip it it. Will lube your chain,and bearings and do wonders for the saddle too. That sheeet seems to be good for most everything,but is said to work best on Italian stuff.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
EDIT: I didn't notice when I replyed that it was Sydney that made the olive oil comments. Clearly he was joking...and I didn't recognize it.
To protect parts from rust, keep them clean and free from salt from sweat. A little WD-40 also won't hurt, particularly if there is water present.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
You Know!? For Kids!
Originally Posted by Nessism
Olive oil is NOT the proper lubricating oil for ANYTHING on a bicycle. It's better than nothing but that's about it.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
I like to use car wax on surfaces I'm protecting from rust. I keep my WD-40 away from my bikes. Being Italian, I keep my Olive Oil in the house where it belongs, in the kitchen. (I wish I could afford an Italian bike.)
Roccobike BF Official Thread Terminator
barnfullagts
Bikes: GT BI Ti/BI Steel - Edge Ti and Steel Xizang Ti and Psyclone Steel
WD-40 doesn't have any staying power. It's good for a few days and after that i't useless. When I wrenched we always used the LPS-2 product instead of WD-40. It sprays out a little heavier. Not so thin
I did a little searching and Boeshield sounds like a good product for rust and corrosion protection. It makes a good chain lube as well. It was developed for Boeing and leaves a thin coat of wax on surfaces.
Sears sells it.
LPS-2 also sounds good, but it's a wet lube, which will attract dirt (Boeshield is dry). Since I live in sunny So Cal, I'll go with Boeshield.
Sears sells it.
Quoted: 19 Post(s)
Liked 7 Times
I used a steel bike in a coastal town for 5 years. I sprayed inside the steel tubes with WD40 and they stayed bright and shiny. Not to be done if your BB has replaceable bearings but it works for a sealed Shimano cartridge style.
For the outside, WD40 and oil washes away too quickly.
Grease attracts too much dirt so should be used on metal-metal contacts (eg threads) only.
I protect exposed metal using wax. Pretty much any wax will do, car wax, furniture polish. All exposed cables, bolts and the frame get cleaned and wiped. Keep away from rims.
The Rabbi
Quoted: 16 Post(s)
On cables and in my frames I generally use Boeshield T9. It was made to prevent corrosion on airplanes, and leaves a nice waxy residue that stays on forever. Works great as a chain lube too.
I'm going to try the Boeshield T-9. On their website, they also sell a "Boeshield Bike Lube" in a smaller bottle. Do you know if it's the same stuff (T-9) sold in the larger containers, or if it's a different product specifically for bikes?
This thread from a few days ago lists a few additional alternatives. I have some LPS-3 which seems to work okay so far.
For me, a bigger issue is how to apply it effectively to ensure full coverage. Seems like the seat tube is about the only place where you have relatively open access. Just about everywhere else, you are spraying blind through vent holes and hoping you are coating everything.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
i use Silicon grease. Apply lightly and wipe of so that just a thin film remains. Next week wipe this off and reapply. Thin film only please.
Hi, I'm looking for a product that is good for rust protection/prevention? I live 1/2 mile from the salty waters of the San Francisco Bay, I just bought a new bike, and the space in my apartment is small, so I'd like to leave my bike out on the balcony. My fiance's older, less expensive bike has been stored on the balcony for 2 months, and I've noticed rust has built up on the handle bars, crankshaft, and other steel parts.. No 100% sure the rust was a result of it sitting out on the balcony, it was previously stored for months in a garage not close to any salt water.. I would like to keep storing the bikes out on the balcony without this rust from building.
-- i've submitted this question to Boeshield regarding their T-9 product since I didn't see "rust protectant or rust prevention" listed as a feature or benefit of the product. Can anyone else advise to a product that will fit my needs? Thanks!
Quoted: 840 Post(s)
Liked 336 Times
You can find research results e.g. here. I mix T-9 with LPS 3 and ACF 50.
Quoted: 4201 Post(s)
Liked 3,857 Times
In the end I have found that your personal touch is the best long term rust management. Sure products can be sprayed, dripped and brushed on but all will break down and or rub off. It always comes down to your cleaning and reestablishing what ever method you chose. Andy.
Liked 3,857 Times
I wonder what your experience would be if you lived in a high salt location like Santa Cruz or Cleveland. People far smarter and greedy then us have tried to solve this problems for hundreds of years and yet we're still asking the same questions. If we had a real answer then the US Navy could save millions each year on ship maintenance. Andy.
Quoted: 840 Post(s)
Liked 336 Times
I ride the whole winter with bike covered in slush saturated with salt dispensed on the roads. My mixture evolved over time until I got to the stage where I could quit worrying about corrosion.
