Loctite blue
Hauja
Bikes: not as many but still too many
I have just converted my Dahon Getaway ( 20 inch wheel coaster brake single speed) to a fixie with a bmx wheel and 16T fixed cog secured with loctite red. I have used this method before with a 16 inch wheel bike as a winter rider. It works well and safely for recreational riding on snow and ice.My question is has anyone used loctite blue to do the same thing. To get the cog off while using red i will have to heat it to 260 degrees to loosen it . A cog secured with loctite blue would be easier to remove should i ever wish to, but is it safe?
i am sure that i hate you
Bikes: 'Cha-ruzu Fosuta Orusan Kein' Fuji Track (2005), Schwinn Tank MTB (?), Fuji Royale (1979)
i was curious if anyone had made fixed conversions out of the Dahons or any other folders.
putting the pi back in pirate!
It’s an upstanding member of the solar system
Apply the laws of earth and make it a victim
Of Proposition 187
Of Proposition 187
o.O
Do you have a bb lockring? with that, assuming it's tightened enough, the cog isn't coming off even if you don't have any loctite at all. Way more likely that the threads will eventually strip.
I run my bumbike hub with blue loctite. It's been flawless for almost 2k miles now. I skip, skid, aggressively backpedal, etc. Not a single problem. I gots a front brake also. Works for me.
we're here, we steer!!
i think its mentioned before, but if you're not running a brake, please wear a ginormous bright orance dunce hat on your head so we can all stay far far out of the way.
kthnxybye.
kthnxybye.
likes avocadoes
Bikes: heh, like that info would fit here...
The problem is that you have competing goals:
1) want the cog to not unthread itself when riding
2) want the cog to come off easily when wrenching
The solution is to use the correct technology (a fixed hub with a reverse-threaded lockring.) If you're going to cheat on that solution, then don't expect good results, choose either safe to ride and hard to remove, or suicidal but easy to wrench on. I'd go with the red AND a bb ring.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
So, the only REAL way to get a safe fixed hub on that bike is to find a 110mm keirin rear hub ($$$$$) or convert a 120mm hub by removing spacers (Suzue's and DA's, usually). Either way, a boatload of cash for one lousy tiny wheel.
Or, you could just keep using your suicide wheel with a brake. I did it all summer with a rotafixed blue loctite wheel. Not much skipping or skidding, but it held anyways.
fixed.se
fixed.se
BTW, these cheap hubs can easily be respaced to 110mm
https://www.sjscycles.com/store/vIndex.htm?item11137.htm
ps. I used green Loctite and rotafixa method to secure the lockring. And itäs kinda hard to skid with this bike.
shoot up or shut up.
Bikes: yes please.
it's completely safe. it comes 'highly' recommended. don't be a baby and use brakes either.
Fear the banana
Bikes: 1950s EG Bates track & 1960s Frejus track
Originally Posted by Boe
Thats wild
Hauja
As I stated I have had good results with red loctite if i could afford a track hub and a handbuilt wheel I would buy them.I really would like to whittle down my number of bicycles and a fixed and free wheel would eliminate one bike.I am however currently financially challenged ,so food, shelter ,my phone bill etc take priority. I never stomp and i do not skid the wheel.I also run a front brake.I ****** the the pedals to slow the bike but i do not go that fast anyway .The 20 inch wheel fixie ( Dahon Getaway)will be my antidote for cabin fever.My 16 inch wheel fix( Dahon formerly a classic 3) allowed me to play on ice and snow without falling.The 20 incher should be slightly faster.Tires are tioga comp 3's 20 x 1.50 inflatable to 60 psi.
Hauja
I have four fixed conversions 2 Dahons and 1 yeah ( A liscense built Dahon clone ) All use a fixed cog and red loctite .I also have Roll N fold fixie 14 inch tires with a fixed cog and red loctite . They all fold. The roll n fold went with me to Milwaukee Wisconson and Coronado California in a suitcase.
