35mm headset wrench?
stare master
Any idea where I can get one of these? Or what I can use in its place? Park discontinued its 35mm/36mm headset wrench, I haven't been able to find anything else.
Quoted: 128 Post(s)
Liked 12 Times
Honestly, your best bet would be to just use an adjustable open-ended wrench. Unless you need a cone-width 32mm, in which case you'll still need to find a more traditional headset wrench, on which point I can't help you. Good luck.
"c" is not a unit that measures tire width
ride, paint, ride
https://www.performancebike.com/shop/...&slitrk=search
edit--sorry, I thought a 36 would work if you only needed it for a 35 mm adjustable cup on a headset, since it doesn't ever have to generate much torque on the flats of the adjustable cup race. It just needs to be flat enough to fit under the locknut when a wrench is on it. But I guess 36 mm headset wrenches are pretty easy to find, sorry about that.
Klaatu barada nikto
Originally Posted by lawkd
Performance sells one, I have it and it's a nice one.
to make a (oval with 35.1mm flats) wrench for that but I have not been able to find one anywhere.
I guess the moral to the story is that when you seen some of these "standards" fading away, it just may be worth it to pick up the specialty tools that are associated.
I agree that an adjustable will work just fine. If you have some fancyshmancy headset that you're worried about marring, just put on a layer of electrical tape and then tighten the adjustable as tight as you can. It will be better than a 35mm open end. Use the biggest adjustable wrench you can get your hands on - even better. Good luck.
Klaatu barada nikto
You can find 40 different headset wrenches here:
https://www.biketoolsetc.com/index.cg...et&tc=Wrenches
Unfortunately, none of them are 35mm ;-( If you can't find the tool you're looking for at this site, it's likely going to be very difficult to find it anywhere.
stare master
Originally Posted by cascade168
Just curious ... What headset uses 35mm?
cascade: Thanks for the link - what about this one?:
https://www.biketoolsetc.com/index.cg...s&item_id=ZG-9
I've never heard of zog's, but that might be my ticket.
I don't think an adjustable would work, not enough room to get in there. The headset came with a 1991 parkpre hammer mtn bike. Not sure what make it is.
Thanks again!
Klaatu barada nikto
Thanks again!
Thanks again!
