help with bb removal
Bikes: 85 bianchi stelvio, 80s Rossi, 80s Fiori modena
Pick up an old beater Raleigh Ambush. There was play in BB axle, got the crank arms off, and lockring. Cant get the cup off. IT has a raised ridge across it Im banging it with a slot srewdriver and hammer no movement. Any help is appreciated I want this bike ready for the snow. Thanks Keep on Keepin On !!!!!
Quoted: 2026 Post(s)
Liked 1,096 Times
Drip a lot of penetrating oil (Liquid Wrench or similar) on the threads and apply mild heat with a hair dryer. Repeat several times. A large adjustable wrench can be used to span the raised ridge and should allow more torque than the screwdriver you are in the process of ruining.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
Replace the ball bearings when you finally do get it apart.
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
See also: https://sheldonbrown.com/raleigh26
Sheldon "Nottingham" Brown
Code:
+--------------------------------------------------+ | The word processor to end all word processors: | | https://www.e-2.org/perhect/frame.html | +--------------------------------------------------+
The Red Lantern
A bench vise works pretty good to.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Liked 1,096 Times
Originally Posted by Bobby Lex
Make sure u r turning in the correct direction. It's not always "righty-tighty, lefty-loosey"
Thanks guys,just got in. Im on the left side of the bike, non drive side. Im turning counterclockwise. Used some antiseize product and heat no luck. Ill try other sugestions tomorrow. How about drilling two holes in it . Thanks Im getting this thing off one way or another.
Quoted: 24 Post(s)
Liked 6 Times
Sheldon "Unnngggggggghh!!!" Brown
Code:
+-------------------------------------------------------------+ | If brute force doesn't work, you're not using enough! | | --BOB Simon | +-------------------------------------------------------------+
如果你能讀了這個你講中文
if you can get the adjustable cup off, leave the other one in, clean it a bit, and feel around with your finger on the fixed cup for pitting. if pitted, follow Sheldon "Unnngggggggghh!!!" Brown's advice. If not pitted, maneuver some grease into there, used caged bearings, and reassemble.
You guys answered my question, Sheldon article was excellent. I know the process to remove it now. Just have to find the time. Again thanks. This forum Rocks!!!!!!
