Shifter compatibility
Old 12-02-05, 04:23 AM
ch9862's Avatar
I have Trek 520 w/road handlebars. If I were to change handlebars to straight, which shifters and brake levers could I use? I think the bike has 105 front and Deore LX rear derailers, plus Avid v-brakes.
TIA
ch9862 is offline
Old 12-02-05, 06:47 AM
slower than you
Applehead57's Avatar
Bikes: Gunnar Road Sport, peugeot UO-10
I changed my 1977 Peugeot UO-10 from road to straight, and found that I lost alot of hand positions. It was downtube shifter so that wasn't affected.
That meant I had to constantly move my hands to keep them from numbing.
Just a thought.
Applehead57 is offline
Old 12-02-05, 07:49 AM
TallRider's Avatar
Quoted: 128 Post(s)
Liked 12 Times in 10 Posts
Most integrated shifters/brake levers for mtb bikes (like the current LX) have brake-lever pull for V-brakes (which require the lever to pull a lot more cable). You could switch to V-brakes, or find a Shimano brake/shift lever that is designed for cantilevers. If you get a shimano shifter for the proper number of speeds (8 or 9 on your bike, probably), it'll work fine. You could go with grip-shifters alternately, and having a seperate shifter would allow you to purchase brake levers specific to cantilever brakes.
However, if you're using the bike for long rides and/or touring, I would also recommend against the flat bar. If you want a more upright position, you you could get a higher stem with your current handlebars. Or, alternately, get moustache bars. Rivendell sells some good ones:
https://www.rivbike.com/webalog/handl...ape/16027.html
Moustache bars offer a wide variety of hand positions, work with your current brake levers and bar-end shifters, and look pretty cool to boot. I've got them on my commuter and like them. You'd probably want to buy a stem 2cm shorter than your current one.
"c" is not a unit that measures tire width
TallRider is offline
Old 12-02-05, 10:15 AM
ch9862's Avatar
If I were to ride the bike, I'd keep the road bars. I'm setting it up for my better half however, and she won't have anything like downtube or bar-end shifters. Looking at the prices of some MTB brake/shift units made me think that perhaps road brifters are the way to go (8 speed Sora can be had cheaply), but SWMBO wanted straight bars (and I don't have to worry about them working with v-brakes).
Hence my question in the technical forum (I don't know anything about MTBs). Are SRAM grip shifters compatible with Shimano derailers? What about units marked as compatible with SRAM 1:1 derailers? Are any of the MTB brake levers incompatible with v-brakes?
TIA
ch9862 is offline
Old 12-02-05, 10:44 AM
TallRider's Avatar
Quoted: 128 Post(s)
Run the moustache-bar idea by your wife. It would be a good option.
Lots of SRAM shifters are shimano-compatible. I think that SRAM's own 1:1 deraillers and shifters aren't Shimano-compatible. Sora brifters wouldn't be very good on a flat handlebar.
And if you get mtb levers, make sure they're the kind that are incompabitible with v-brakes, since you have cantilevers.
Old 12-02-05, 10:52 AM
hello
roadfix's Avatar
Quoted: 191 Post(s)
Liked 109 Times in 48 Posts
Yes, if you want to try something different, go with moustache bars. It's pretty much a hassle free swap.
roadfix is offline
Old 12-02-05, 10:58 AM
dbg
Si Senior
dbg's Avatar
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times in 8 Posts
I went through several rebuilds for my wife's bike including some "antler" setups (various forward hand positions with brake extensions), swept back uprights, etc. She didn't like any of them. She now has straight bars with grip shifters. I added bar-ends for an extra hand position. Shimano-compatible SRAMs will work fine (what I used). I aslo used the brakes with upturned lever extensions so they can be used from the bar-ends (jury is still out on that one).
dbg is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
