spoke length can I get away with 1 length?
I used the DT spoke length calculator to arrive at spoke lengths of 293mm & 294mm for the two sides of my rear wheel. Miche track hub on Open Pro with 14/15 double butted spokes. I'm wondering if that 1mm is crucial, or can I get away with using 1 spoke length either 293 or 294.
The Red Lantern
Yes you can get away with it. There is always a little variation in the rims and hubs anyway. Some of the old calculators like Blue Pig used to let you put the measurements you got for the parts in every time you measured and kept a running average.
I would go with the 294, you might have just a little hangout, but with the boxed rim it won't matter and you will have a full thread engagement .
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
The Red Lantern
Dt Swiss is great but you need to be able to measure your rim and hub.
https://www.dtswiss.com/index.asp
If you do much building you can get the DT wall chart calculator pretty cheap.
Take a look at https://home.earthlink.net/~mike.sherman/bike.html#WHEEL
The full version of Spocalc has a reasonable hub/rim data base but requires Microsoft Excell or the freeware substitute listed on the above site/link. The data base does not include Mavic Open Sport or the Trek "no-name" hubs that I am working with......dig out my metric calipers/ruler.
Happy building!
Happy building!
Liked 7 Times
If faced with that choice go with the 293's, better to be 1mm short than to run out of threads on a long spoke.
Al
Al
lunatic fringe
Bikes: 1980 Schwinn World Sport, 1982 Schwinn Super Le Tour, 1984 (?) Univega Single Speed/Fixed conversion, Kogswell G58 fixed gear, 1987 Schwinn Super Sport
Originally Posted by 531phile
hey chuck, is there an online database with proper spoke lengths for rims and hubs combinations?
SPOKE LENGTH CALCULATOR
Dogbait
The Red Lantern
I just measured up a spoke and nipple. Both Dt, 14g spoke, 12mm nipple. The spoke can protrude 1.25mm past the nipple before it bottoms on the threads. The groove in the the nipple measures 1.3mm. The threads in the nipple start 3.6mm from the lip.
In theory a calculator tries to give you full engagement, that is to the bottom of the groove in the nipple. So, in theory, you have 2.55mm before you bottom the spoke in the nipple. I still say go 294, if you used the Dt calculator. If it bottoms out I will paypal you a dollar.
When I rebuilt my wheel, I noticed that the spokes were pretty far past the nipples. No problems though. I think the threads are taller than the diameter of the spoke.
The Red Lantern
"They bottom out? Huh?"
Depends on the spokes and nipples. I have had some you could thread the spoke all the way thru and the nipple would slide up and down the spoke, not often tho.
