Will RainX prevent my glasses from fogging up?
demon speeder
Bikes: commuter: Kona Fire Mountain Road: Mongoose Pro Bosberg
My breath fogs up my glasses when I wear my balaclava and I was wondering if I treated them with RainX (or other similar product) if that would at least minimize the fogging.
suggestions?
solutions?
suggestions?
solutions?
Bikes: 2005 MTB
It depends on which RainX product you are referring to. The company makes several products under the name RainX including an anti-fog treatment.
See their website here and click on the Products link then the Windshield Treatments link.
RainX
RainX
Bikes: Early 80s Motobecane Grand Touring
Skiers have been using an anti-fog lens cleaner called Cat Crap on their goggles for years. I've never tried it, but have met many who swear by it. Since most goggles are poly, I can't imagine it would harm plastic lenses... www dot catcrap dot com
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Don't know about that, but another thing to try is to insert a vapor block. PSolarX has one that they sell for $5, but I googled around and found that it's just a hunk of foam cut to fill in the gap formed when the fabric stretches straight from your nose to your cheek. I made one in about 15 minutes (took a couple of tries) and taped it inside the balaclava with carpet tape. Stops most of the vapor.
Listen to me
You can wear vented ski gogles over your glasses to prevent fogging.
To improve rain vision buy/cobble a large visor for your helmet.
Enjoy
Enjoy
I've tried both RainX and Cat Crap with little success. What has been working for me, even in this cold weather, is a new nanotech product called Clarity Fog Eliminator.
https://froogle.google.com/froogle?q=...Fog+Eliminator
Applications, with a dry Clarity cloth on clean glasses, lasts about a week.
demon speeder
All great suggestions. Thanks. I was able to get my hands on a surgical mask here at work and I took out the metal nose piece and inserted it into the seam over the nose of my balaclava. That didn't eliminate the fogging but it did help and it was free. I might try the surgical mask itself.
Airborne Titanium
Bikes: Airborne Ti Upright, Raleigh M-20 beater, Peugeot Folding
People use Rain-x Anti-Fog (I recall it being Fog-X when I was a kid) on the insides of motorcycle helmets which are plastic without any problems, so glasses should be fine.
Enjoy
Bikes: Trek 5200
Originally Posted by LittleBigMan
I thought about RainX too, but I'm not sure my plastic lenses will be ok.
Macaws Rock!
Bikes: 2005 Soma Doublecross
Rain-X is not an anti-fog chemical. It is designed to make water droplets slide together in a sheeting action and blow off. I have used it on motorcycle helmet shields and it does NOTHING for anti-fogging, although it does make droplets blow off at 70MPH if you turn your head sideways.
I don't think it will be at all effective for bicycling purposes.
San Francisco, California
You might try a scuba shop. They have products used for antifog while scuba diving and snorkeling. My wife and I have used some while snorkeling and it seems to work well. I assume it would work for our application too. Plus its cheap. I think I paid 2 or 3 bucks for what we got.
Chronic Tai Shan
Bikes: Pake Single Speed
Its active ingredients are Silicone Oils, Siloxanes and Silicones, di-Me, hydroxy-terminated. These chemicals form Si-O-Si bonds with the surface of the windshield and have Methyl-terminated hydrophobic tail group which repels water. So, it should only work on true glass that is silica based, as the bond will only form with the Si-OH groups that are on the surface of the glass.
G-Si-O-Si-O-CH2-CH2-CH3
L-Si-O-Si-O-CH2-CH2-CH3 ---> Water
A-Si-O-Si-O-CH2-CH2-CH3 ---> Water
S-Si-O-Si-O-CH2-CH2-CH3 ---> Water
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
I have tried products similar to Rain-X. Oh yes the lenses (polycarbonate) don't fog. Instead I had a blurry film of water on the lenses. Might as well not wear lenses or goggles. Does not work in freezing conditions
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
I wouldn't recommend it. The teflon coating will cause water to bead even more but it's not clingy so it'll combine with other water to make large puddles.
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
Most glasses whether plastic or glass use coatings like anti-reflective, UV etc; Rain-X will remove those coatings! Read the bottle, it says not be used on paint or rubber or plastic...why? because it will remove any coatings, could damage paint, and eventually would make plastic dull out.
bk
I would be very careful about using RainX if your lenses have any type of anti-reflective coating that you're interested in keeping.
Bikes: Dawes Double Blue, Vision R-42 SWB, Bacchetta Giro, Lemond Maillot Jaune, Lemond Washoe, Holdsworth Special, Gitane Champion du Monde, Bob Jackson World Tour, Bianchi Professional, Nashbar C/Tour
As a motorcyclist, I've always been told that Rain-X should NOT be used on helmet shields. I've never tried it because of the warnings. Lemon Pledge works pretty well with rain, but wouldn't be any help for fogging. I would recommend visiting an on-line motorcycle shop (Helmet Harbor, Dennis Kirk, etc.) to see what sort of products they have.
Bikes: A MTB and something else with 2 pedals.
Toothpaste on lenses?? Are you NUTS! The last time I checked , toothpaste has abrasives!
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,527 Times
I'm so glad my vision is okay enough that when my glasses fog up I can just take them off.
Quoted: 4802 Post(s)
Liked 3,922 Times
When I tried Rain-X many years ago, I found that what I could no longer do is a simple wipe to remove moisture. That wipe instead smeared the Rain-X and destroyed my vision. As one who has to wear glasses - heavy prescription - that is for me, completely unacceptable.
I find a simple wipe with my index finger does a smooth smear of the dater drops and I can see quite well.
Ben
Ben
