Sugino RDs
meet the mets
Bikes: Raleigh conversion (hours spent making it look like a Pista); Porter Track, Samson Track, Leto Roadie.
Sugino RDs
[This is a purely academic question...I just bought 75s and love them.]
Does anyone run the Sugino RDs?
Up until now, I had only seen the black crankarm ones, which looked kind of cheesy. These, though...I think they look pretty good, and at this price point, I would think we'd hear a lot more about them than we do. Anyone have these, or have any thoughts about them?
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Yes
roll'em high
i had a pair. they will feel extremely flexible if you have ever ridden on better cranks (sugino 75, dura-ace). the rd's are single or double chainring cranks and take a 103mm bottom bracket get a really solid chainline (the 05 pista shipped with rds and a 103mm bottom bracket, in any case). you would be better off buying a used set of shimano ultegra double cranks (older ones -- shimano 600 or whatnot -- that are less ****ing ugly). they will be a lot stiffer and no more or less a "track crank" than the rds. they work well with a 107mm bottom bracket.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I've been thinking about getting the XD's so I can run a left-hand drive setup. That would be cool...
Dirty White Boy
Bikes: 2004 Specialized Sirrus Comp, 1984 Raleigh Gran Prix fixed gear conversion
I run them as well. I like them, but I'm a FG newb and have never used any proper track cranks, so I can't comment re: stiffness. They're the right price, though.
bought a new car
Bikes: 01 Pista and 99 Lemond Chambery
The length of the arm on these doesn't actually change, they just drill the hole in a different spot. To me that says cheap ****.
Bikes: DW
there's a clear and present danger of crank-strike, apparently.
seriously i had a pair and they were ok until you try something better and realized how good a dedicated crankset is
Arizona Dessert
Liked 2,169 Times
Al
Arizona Dessert
Liked 2,169 Times
Al
Bikes: Gios track,Miyata roadie, GT mtb
I had'em. Worked okay, but fugly (chainring usually has to be inside the spider arm to get chainline right).
Better off with used shimano 600.
likes avocadoes
Bikes: heh, like that info would fit here...
King of the Hipsters
Bikes: Realm Cycles Custom
I ride with Sugino RD's and like them because of all the different (and cheap) 130mm BCD chain rings I can use.
I have found the ability to move the chainring between the inner and outer positions gives me the ability to accomodate a greater variety of sprockets and still have a good chain line.
i believe in me
i have RDs and dig em, although i havent ridden with a better crank. i think im getting 75s for the new frame, but the RDs are great for the beater. cheap, flexible as far as chainline goes cause you can put the chainring on either the inside or outside, and pretty nice lookin.
i dig mine. for a conversion that'll never see the track i think they're a bargain. lots of chainring choices, easy chainline setup, stiff enough for my flexy steel frame.
