Wheelbuilder new to Wheelsmith products
Bikes: Klein Quantum Pro
As some of you know, I've built many a wheel with DT spokes and nipples. I have a request to build a wheel set using Wheelsmith spokes. I'll be using the DB14's. It seems the vendor I'm going to use only carries spoke lengths in even numbers.
I've calculated my spoke length as:
Front - 283.7
Rear - 282.9/282.4
For the purposes of this question, let's assume my measurements and calculations are accurate.
With DT spokes, I'd round down to 283 in the front, 282 on the non drive rear and maybe 281 on the drive side rear. That seems to work.
I need counsel from those of you familiar with Wheelsmith product. I understand WS nipples have thread all the way through, so they are more tolerant of spoke length issues. I'd like to go 282 in the front, 282 on the non drive side. I'm not sure where to go on the drive side. 280 seems short. What do you Wheelsmith officianados say? Thanks in advance.
Front - 283.7
Rear - 282.9/282.4
Quoted: 1572 Post(s)
Liked 643 Times
My rule of thumb for spokes is plus or minus 1mm will work fine. In you're example, using only even sized spokes, I'd use 284mm for the front and 282mm for both sides of the rear.
Bikes: late 80s Paramount MTB with Xtracycle, late 80s Paramount MTB converted to single speed, Bianchi Nuovo Record converted to fixie, custom Tom Board lugged steel racer, 1950s Claude Butler, 1950s Dawes, custom chopper built on 50s cruiser by me
If the rim's eyelet has a deep enough cup (and I haven't built on a rim in a very long time that didn't), and I have a choice, I round up since any slightly protruding spokes won't be a problem. But, yea, when all is said and done Retro Grouch is right, + or - 1mm shouldn't make a difference.
Don't forget to jot down some notes once the wheel is done.
The Red Lantern
Same here. round up.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
