Front Derailer - Can it be done ?
Old 12-26-05, 04:35 AM
Is it possible to install a front derailer upon a bike that has no cable stops ?
Guy Yinon is offline
Old 12-26-05, 04:46 AM
filtersweep's Avatar
Yes. You should be able to find some old vintage clip-on cable guides. It might not be pretty....
filtersweep is offline
Old 12-26-05, 07:52 AM
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
There's always a way but it depends on the particular derailleur and bike. One way is to run cable housing all the way from the shifter to the derailleur and tie it to the frame tubes with wire ties. Like filtersweep said: "It might not be pretty."
Retro Grouch is offline
Old 12-26-05, 08:40 AM
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Quoted: 559 Post(s)
Liked 629 Times in 280 Posts
I have a dept. store Huffy 12 speed out in the barn with all the cable guides and stops front and rear cast into the derailler mounting, which champs onto the seat tube and rear dropout. Never saw anything like it before....
Top
top506 is offline
Old 12-26-05, 08:43 AM
118AHC "Thunderbirds"
2372ighost's Avatar
Bikes: Numerous (wife says to many)
maybe here:
https://www.loosescrews.com/index.cgi...d=212261410693
2372ighost is offline
Old 12-26-05, 03:37 PM
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
Pulll out the torch and braze one on!
DannoXYZ is offline
Old 12-27-05, 09:39 AM
Don Cook's Avatar
Bikes: Raleigh, Benotto, Schwinn, Trek
You didn't identify the frame configuration, so I'll toss this in: if you install a downtube shifter for the front derailleur and you're using a bottom pull setup, you don't need any cable stops.
Don Cook is offline
Old 12-27-05, 12:11 PM
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
https://www.biketoolsetc.com/index.cg...20Cable%20Stop
2_i is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
