("comfortable") CADENCE AND SPEED?
hell's angels h/q e3st ny
Bikes: surly steamroller, independent fabrication titanium club racer, iro jamie roy--44/16, independent fabrication steel crown jewel--47/17, surly karate. monkey (rohloff speed hub), unicycle
i'm ridin' 44/16 and accordin' to my cateye trusty cycloputer i'm goin' around 18 mph on the flat with no wind when i'm rollin' with little effort. or put another way, the effort i'm expending is such that i could maintain it pretty much indefinitely. if i was to go to say a 45 or 46 ring would i go faster on the flats at the same EFFORT, not necessarily cadence as i understand that at the same cadence i would be goin' faster in the bigger gear? does this make sense? anyone?
thanks!
thanks!
I bet
Here's a link after some quick googling you can calculate mph with diff cadence and ratios:
https://www.wisil.recumbents.com/wisil/gearinches.asp
Ration and cadence affect mph, spinning is higher cadence. So if you went at the same cadence with higher ratio then you would go faster.
Bikes: RANS Tailwind
If all else stays the same (wind, elevation, etc.) you cannot increase speed without increasing effort. Increasing chainring size will not overcome the additional drag that must be overcome to go faster. Put another way, increasing bike speed is the same as increasing wind speed. And we all know that increasing wind speed means more effort to go the same speed no matter what gearing.
SS
SS
Have bike. Will travel.
Bikes: '06 Orbea Orca, '03 Rocky Mountain Vertex 70, '05 Surly Steamroller, '06 Fetish Fixation
If you want to go faster, then up your big ring. You can expect a little more resistance, but it's doable. I'm riding 46/15 with no problem. You have to fight on the hills a bit but it's totally doable. I can usually go 22mph in a no wind situation and feel good about it
I bet
SS
SS
spin
Bikes: raleigh m-60, azonic steelhead, schwinn world sport fixed gear
what would be considered a high cadence to shoot for.....i did some rough calculations and figured out at approxiamately my top speed ~26mph I would be spinning at ~120rpms I run a 44x17 should I aim to be able to have a higher cadence......I was just wondering about where everyone spins out?
Bikes: Mercier Kilo TT
i'm feeling weird about my cadence/speed lately. i feel like i'm going at a comfortable pace, but know i could be spinning faster, but i'm not trying to put myself in a situation where i cant stop in time...does this mean i need a brake???@?!
or maybe just gear down and spin faster..
ya'll can't mush me
OP: I sprint at around 140rpm on the street. At 28x16 that's about 33mph.
On the track I sprint at (ideally!) 160rpm, which at 52x14 is about 41mph.
Keep in mind that in either of these cases, I have not been known to do so for very long, and I'm in decent shape, and train specifically for cycling, so YMMV. I know target RPM for most roadies is around 110-120rpm. A little lower (90-100) is probably pretty good.
One speed: FAST !
Bikes: Ebay Bikes... =)
how about playing with the numbers in this form, you can then calculate what your rpms are at various speeds and gears....
Cadence Calculator on FGG.com
WOOT !!!
WOOT !!!
Barbieri Telefonico
Bikes: Crappy but operational secondhand Motobecane Messenger
My 42x16 is begging to go away in lieu of my 42X13 ... specially on flats and downhill.
Giving Haircuts Over The Phone
Vanned.
Bikes: 2006 Motobecane Le Champ SL, 2006 Mercier Kilo TT, 2004 Gary Fisher Tassajara
Originally Posted by huhenio
Start looking at skinnier tires too, you would want to decrease rolling resistance. What about riding on the drops more often for starters?
The 23mm tire may have better aerodynamics however.
Note, though that skinner tires often have higher rated max pressures.
