crankset hjelp
I believe I need a new crankset but I don't know how to find out of a crankset is compatible with my bike. My bike is a trek 930 and it has shimano stx cranks on it.
Im wondering if this crankset would fit on my bike
https://wheelworld.com/site/itemdetai...=39&sort=Price
My other question is, why is that xt crank 99 dollars and the other ones they are selling are 250?
Whats the difference between all the different xt cranks, and how do i find out what crank will fit on my bike?
does the one thats 99 not include the other crank arm or something? will i need to buy a compatible bottom bracket?
also which bottom bracket would go with my crankset?
https://wheelworld.com/site/showitem....ory&Catalog=39
Im surprised the ****** who makes a topic about pineapples gets more replies than this topic which actually is about a valid thing to do with mtbing.
Dismember
Bikes: Kona Kikapu/hoss deluxe mix, 1950's Malvern Star gent 28" turned into a stealth commuter with drums and a three speed.
If Im correct(not often) then stx is old time shimano long gone and has a taper fit or square bottom bracket to crank fit. In which case no that xt wont fit as it has an octalink type crankarm fit. Get someone whos knows to confirm the type of BB you have and if it is square you could cruise ebay for square or taper fit crankarms. Or try pricepoint.
Yeah, pineapples belongs in Foo.
Ebay
Ebay
Mmmmm...shiney new parts...mmmm
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
RAIYN THANK YOU, you are the single most valuable information source on this site.
also, will any of the xt bbs work with that crank? or is there a specific one, if so link me to which one.
how do I figure it out? is there a way to see what size a trek 930 shell size is online?
Originally Posted by Raiyn
It's likely a 68, but aside from contacting Trek (or getting lucky here) your best bet is to see what your current one is when you yank it. Don't just take my guess for a fact on this one
also, they have 68x107,110,113... so on.. my bb will say exactly what dimensions I assume?
Ok, so basically I need to pull my crank. Problem is I don't know how to use my crank puller. But, you've been an amazing help raiyn.
Crank removal
https://www.parktool.com/repair/readhowto.asp?id=103
Bottom bracket removal
https://www.parktool.com/repair/readhowto.asp?id=94
You can't go by the old one for the axle length (113,118 etc) your NEW cranks will dictate that and I don't have a Shimano manual sitting in front of me.
Im confused what do you mean?
edit: nvm I see what your saying my bike dictates the first number the second one depends on the crank I buy
Bikes: Stumpjumper FSR 30th Anniversary
Cranks and bottom brackets are fun - enjoy!!
Then you need to get the bottom bracket out - start on the non-drive side and then the drive side. After you get it out, you should see the size in the middle of the bb.
If you were me raiyn, would you just go and replace the crank and the bb. I still don't even know what is screwed up, I just know that my crank doesn't turn.
Besides that it's damn hard for me to accurately diagnose a bike over the internet. Take it to the shop and see what they say. If the cranks are f'd then upgrade if you want, but if they're still good to go then ride them into the ground
Ok, thx for the advice raiyn. Im going to bring to the shop, if the crank is screwed ill get the xt setup. My last question is how do I figure out what size im going to need to get for the xt crank? (i mean for the second number)
The only reason Im thinking about getting the xt crank even if my crank aint screwed up is its a great price for an xt crank. My crank as it is has tons of teeth that are bent and starting to come off.
Yea I know, but I mean better crank I can use when I DO get a new bike. If I got a new bike I would have to get a different size bb assuming I do get this xt crank though right?
Well I went to the bike shop and the bb is completely bent in one direction. The guy said all I need to replace is the bb but I asked if he would suggest me just getting a new crank (my old one is in crap shape anyways). So Ive ordered the xt and the bb for it.
My last question is all the cranks have sizes 160mm, 170mm, 175mm, 180mm
what is that a measurement of? the crank arm length or what? the crank im buying only comes in 175mm does this measurement matter compatibility-wise? or is it just a preference when it comes to the bike.
https://www.sheldonbrown.com/cranks.html
Should be stamped on the inside of the arm
