Anyone have experience with 48/44/24 crankset?
Old 01-11-06, 09:04 AM
Which front dr will work with a 48/44/24 crankset?
Jim Brantley is offline
Old 01-11-06, 09:45 AM
wagathon's Avatar
That's a MTB triple--e.g., XT/XTR--for a road bike? If so, the same road triple front dr as for 105, Ultegra, Dura Ace cranks.
wagathon is offline
Old 01-11-06, 09:54 AM
If you go to this faq page by Chris Juden https://www.ctc.org.uk/DesktopDefault.aspx?TabID=3808 down near the bottom is a question about half-stepping. Mr. Juden does not believe current derailleurs will work well with less than a 10 tooth difference in the outer chainrings. I was wondering if this was other tourers experience.
Old 01-11-06, 11:39 AM
lost in the ozone
Bikes: serotta colorado, Trek 620
I experimented with half stepping two years ago. The ramped and pinned chainrings like Shimano would not upshift well at all for me, Then someone suggested I try plain Sugino rings and those worked much better but still required some finese when shifting under load. I think because the chainrings are so close in diameter the chain is more difficult to deflect to the next chainring.
The half stepping didn't do anything for me,I went to 9 speed last year and that brought the higher gear ratios close enough together that I seldom need to double shift to find a comfortable gear.
Hartmann is offline
Old 01-11-06, 08:25 PM
Year-round cyclist
According to Robert Beckman and Rivendell, if you want half-step, a road double derailleur works best.
I had hafl-step back with my 21-speed bike, however, now that I have 27 speeds, I prefer to use a custom cassette which gives me results fairly similar to what I had with half-step plus granny, but with less double shifts. For instance, at some point, my tandem had:
48-38-24 and 13-15-16-17-18-20-23-26-34
Michel Gagnon is offline
Old 01-12-06, 12:50 AM
I use a 105 with mine. It works just fine.
Cyclist0383 is offline
Old 01-12-06, 09:11 AM
Michel and Ziemas, thank you. Nothing beats experience.
Old 01-12-06, 10:55 AM
'Mizer Cats are INSANE
Mentor58's Avatar
Bikes: C-dale T800
I'm an old fan of 'half-step with granny', just curious, do you run the FD indexed, or friction? How picky was it when it came to tuning, inquiring minds want to know. I may just have to play with it.
Steve W.
Who thinks Sheldon Brown's online gear calculator the best thing since sliced bread
Mentor58 is offline
Old 01-12-06, 11:02 AM
af895's Avatar
Bikes: 2003 KHS F20-Westwood folding & enough parts to make several more bikes...
HA! I was just thinking about how much I use that page. Fantastic.
af895 is offline
Old 01-12-06, 11:16 AM
wagathon's Avatar
I have a 22/32/44 on a road bike; however, I also could also have chosen 24/34/48 right off the shelf if I'd wanted a little higher gear (48x12). With this, I have Ultegra index shifting using the new 12x27 DA 10-spd hub.
I had the complex, down tube, double shifting arrangement that you're talking about on my old-old "15-speed" to get the most usable gears out of it as I could at the time. However, I didn't have nearly as many usable (for me), closely stepped gears and easily shifted gears as I have now.
For example, I now have about 17 gears starting below 1:1 with a step of less than about 14" between gears without any double shifting (except with each single change of the rings when going from low to high).
wagathon is offline
Old 01-12-06, 11:41 AM
Gone, but not forgotten
Sheldon Brown's Avatar
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
...hmmm...not sure how to take that...
Is sliced bread actually a good thing? All of the best bread I've ever had came in unsliced loaves... ;-)
Sheldon "Only A Memory Since I Went On The Atkins Diet" Brown
Code:
|  The thing about the cold is that you can never tell how cold  |
|  it is from looking out a kitchen window. You have to dress    |
|  up, get out training and when you come back, you then know    |
|  how cold it is.		   	                -Sean Kelly  |
Sheldon Brown is offline
Old 01-12-06, 11:51 AM
Steve W.
Indexed. Not to fussy, all is okay.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
