Go Back  Bike Forums > Bike Forums > Winter Cycling
Does your cyclo-computer work under 32?F
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Does your cyclo-computer work under 32°F
Old 01-13-06 | 07:29 PM
20 Anniversary
Does anyone have a cycling computer that works under freezing. My Micro-Wireless does not work so well. The display is fine but the transmitter isn't quite doing the job.
The transmitter battery is rated to 6,250 miles. I put about 700 on it. I HAVE been able to get this to work by putting the receiver about a foot away from the transmitter.
I think I'll try a brand spanking new battery and see if that helps. But my question here is does anyone have a wireless cylco-computer that works "just fine" when it's under freezing???
willtsmith_nwi is offline
Reply
Old 01-13-06 | 07:30 PM
Mars's Avatar
coitus non circum.
My Cateye is pretty iffy below 40F.
Mars is offline
Reply
Old 01-13-06 | 08:01 PM
CastIron's Avatar
Sensible shoes.
Bikes: A few.
Cateye wireless failed below freezing. Replaced with a Planet Bike Protoge 9.0 (wired) and have had zero temp issues.
Mike
Originally Posted by cedricbosch
It looks silly when you have quotes from other forum members in your signature. Nobody on this forum is that funny.
Why am I in your signature.
CastIron is offline
Reply
Old 01-13-06 | 08:22 PM
Mtn Mike's Avatar
Super Biker
20 Anniversary
Bikes: 2014 Curtlo, 2006 Serotta Coeur d’Acier, 2005 Independent Fabrication Steel Delux, 2003 Surly 1x1, 2003 Surly Cross Check, 1986 Schwin Worldsport SS commuter, 1980's Mongoose Supergoose
My cateye Enduro wired hasn't had any trouble at any temp
Mtn Mike is offline
Reply
Old 01-13-06 | 09:22 PM
Machka's Avatar
In Real Life
Titanium Club Membership
20 Anniversary
Bikes: Lots
I have never had any of my computers completely fail on me on my sub-freezing rides, but what does happen is that the screen goes black.
I currently use a Topeak, and I've taken it down to about -16C/0F ... it still functions, but half the screen is black and it takes a long time to change from one 'view' to another (so I just leave it on Distance)
Machka is offline
Reply
Old 01-13-06 | 09:27 PM
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
My Cateye Mity 3's have NEVER failed in temps below 0 F. The numerals change a bit slower when you get below 0 but still reads out correctly.
Ironically, my cellphone didn't work one day when it was -5 F, yet my Mity 3 still did.
Portis is offline
Reply
Old 01-13-06 | 09:34 PM
Machka's Avatar
In Real Life
20 Anniversary
Bikes: Lots
Sadly ... my Cateye Mity 3 took wing and flew away from me in the middle of the Great Southern Randonnee in Australia.
It was a good computer!! I don't recall having any trouble with it not working in cold temps.
Machka is offline
Reply
Old 01-13-06 | 09:50 PM
20 Anniversary
it's the battery in the transmitter. it gets weaker in the cold so the range goesway down.. if you can replace it with a lithium battery the problem should go away.
steveknight is offline
Reply
Old 01-15-06 | 07:34 AM
For what it is worth, I use a Garmin FR301. So far, I have used it in the rain, sleet, and snow in temps down to around 0F. I keep it strapped to my left forearm, so perhaps that keeps it a bit warmer. I make sure to wipe off the face of any lingering snow or water every mile or so. In a really heavy downpour, I use a small, clear ziplock bag and cover the unit, making small holes for the strap along the back. So far, that works well for me.
Take care,
T
Thomill is offline
Reply
Old 01-15-06 | 07:43 AM
dobber's Avatar
Perineal Pressurized
20 Anniversary
I though Lithium's had cold weather performance problems?
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Reply
Old 01-15-06 | 09:14 AM
Severian's Avatar
META
Bikes: Gary Fisher Aquila (retired), Specialized Allez Sport (in parts), Cannondale R500, HP Velotechnic Street Machine, Dented Blue Fixed Gear (retired), Seven Tsunami SSFG, Specialized Stumpjumper Comp Hardtail (alloy version)
I've got a Vetta V100 wireless that only has issues below 0f. And then it's just that the LCD is slow to respond.
Severian is offline
Reply
Old 01-15-06 | 12:42 PM
20 Anniversary
My Garmin 301 has functioned at -20C. Any colder and I stop functioning.
woof is offline
Reply
Old 01-15-06 | 02:52 PM
Stacy's Avatar
Car-Free Flatlander
Bikes: Sirrus
I have a couple of regular routes where i know the mileage. Several times last year, when the temperature dipped below freezing, I noticed my Cateye Velo 5 had only logged about half as many miles as I knew I had cycled. It also tends to temporarily short-out when moisture gets between the cyclocomputer and the bracket.
So far so good this year except those plastic zip ties are popping so I have to come up with other ways to attach it to the bike.
Stacy is offline
Reply
Old 01-15-06 | 03:53 PM
gboy's Avatar
accident-prone
20 Anniversary
Bikes: Brodie Romax Cyclocross
My Vetta 100's worked till -30 C.
gboy is offline
Reply
Old 01-15-06 | 04:00 PM
OC Roadie's Avatar
Out of Commission
Bikes: Felt FC, S-Works Roubaix, Epic Comp, Cyfac Proxidium
My Specialized Turbo Pro (wireless unit) did pretty well today. The low was 26 F, and we hovered in the 32 F range for quite a while.
If you don't have anything nice to say about anybody, then come sit next to me.
OC Roadie is offline
Reply
Old 01-16-06 | 08:55 AM
Mity3 worked fine this morning -15C. Colder and the display is iffy, but it still records the distance and everything for viewing when it warms up.
ghettocruiser is offline
Reply
Old 01-16-06 | 05:08 PM
Daily Commute's Avatar
Ride the Road
20 Anniversary
Bikes: Surly Cross-Check; hard tail MTB
My Specialized computer has had no problem at 0F, other than my ability to push the ******* buttons with thick gloves or mittens.
Daily Commute is offline
Reply
Old 01-17-06 | 01:07 AM
20 Anniversary
No, lithium and lithium ion batrerries perform better than others in the cold.
I did a replacement lithium. I don't know what chemistry the old one was, it could have been zinc-oxide.
In any case, it's working again for no at 30-40°F temperatures. We'll see what happens when it gets colder. It could simply be that you need a VERY fresh battery in colder weather.
BTW, I found out you can get CR2032 lithiums for $.25-$.50 apiece online. I'll have to find someone to do an order with.
Thanks for the replies everyone.
Reply
Old 01-17-06 | 01:46 AM
Juha's Avatar
Formerly Known as Newbie
20 Anniversary
I've used wired VDO and both wired and wireless Sigma comps in fairly cold weather (-30C or so at the coldest). Displays can get sluggish, but all the computers still registered trip properly. Sigma wireless does eat batteries for breakfast in winter, that is one of the reasons I switched back to wired.
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Juha is offline
Reply
Old 01-18-06 | 12:31 PM
i use the planet bike protégé 9 and it works in the rain and at -30 wind chill
The Selector is offline
Reply
Old 01-19-06 | 03:22 PM
It was -25C today and my VDO C1 was working just fine, although the display was a bit slow.
Cyclist0383 is offline
Reply
Old 01-19-06 | 07:48 PM
I have regularly ridden in minus 20 to 35 degrees Celcius, and have never had any problem with my computer, it is not wireless, and this may have some effect. It is branded as CCM, and I don't know who actually makes it.
torider is offline
Reply
Old 01-19-06 | 08:01 PM
Bikepacker67's Avatar
Bikes: LHT, Kona Smoke
Of course you do.
You're a randoneering freak of nature!
Bikepacker67 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
