mystery front end creaking
make way for the MGL
Bikes: khs aero track
i was riding to work yesterday and was getting this popping up in my front end... almost as if two spokes were popping back and forth over eachother and its pretty loud. i checked and none of my spokes were loose, my wheel was mounted correctly, etc, but i can't figure out what its coming from.
i mostly hear it going faster downhill while not forcing any pressure on the cranks, but don't hear it spinning the crankset or front wheel when its upside down or suspended.
any ideas?
any ideas?
bah
Bikes: WEEEEE!!!!
I was having this exact issue before I rolled out saturday.
It was my right pedal giving it's final death cackle.
keep it pretend
i had a stripped stem bolt (and resultingly, i guess, a couple of other slightly loose bolts)on the front of a threadless stem that was making funny noises. once things got loose enough for the bars to start moving around, i realized what my problem was. got a thomson stem, paid better attention to not over torquing those little bolts and haven't had a problem since.
Lurker for Life
Quill stem? Give the wedge a liberal greasing before putting it back in and tightening it down.
If it's threadless, check that there's no cracks in the bars or the clamping areas.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I had the same problem a few months ago. After a thorough investigation of the bike, it turns out it was the front hub. It had some trashed bearings and the cones were shot. Now it's my spare wheel and I run cartridge hubs.
while i was on my lunch i just spun the wheel for ****s and giggles while my b ike was upside down and i was getting the noise... so i'm 100% positive it's coming from the wheel.
ambassador of good will
Bikes: many.
hmm... that may be it... these hubs have balls in retainers. but this **** is loud and i didn't see any sizable grit when i pulled the hub apart last night. time to repack anyways, so i'll see if that's the problem
troglodyte
howzabout ditching the retainers
would if i could pull the balls out of them. these are retired until i repack/rehardware that front hub.
