fork setup
cptn. x-chains sidekick
Bikes: stumpie, xtr, sid, ultimate sd
fork setup
can someone help me set up my fork... over the internet.
sid team 05
and i weigh 160
it seems like it has to much give with the settings it should be at for my weight.
it sags down about an inch is that normal?
sid team 05
and i weigh 160
Taking "s" outta "Fast"
just fiddle with the settings. Try putting in 10lbs more air and see if you get the sag you want. Then mess with compression, then mess with rebound.
how much sag should i actually be getting.. while just sitting on the bike.. zero?
