Should I upgrade the hubs?
djentleman
Quoted: 129 Post(s)
Liked 102 Times
If there is too much weight combined with to much speed, would those factors be bad for a regular hub with some wear already? Thanks
Quoted: 128 Post(s)
Liked 12 Times
Your question is pretty unclear, and "too much speed" isn't necessarily a problem for hubs... and you might tell us waht sort of hubs you have, how you expect them to be wearing out, what your rims are and whether they're worth rebuilding used rims with new hubs, etc.
But in the meantime I'll just say that it's generally not worth upgrading hubs, because that requires rebuilding the wheel. Unless you have awesome rims. But even in that case, as Bobby Lex said, don't replace the hubs until they're totally dead.
"c" is not a unit that measures tire width
