Natural Chain lubricator
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
I just got samples at a trade show of some stuff called "Air Systems Lubricants." These are non-flammable, non-toxic, and made from plants. The majority of the product line is intended for industrial use, where the lubricants can be spilled without consequence, as the products don't form oil slicks on water. This characteristic relieves a lot of EPA concerns when working on docks and around navigable waterways.
The samples I was given were intended for rods, reels, & guns, but they should work fine on my bicycle too.
I'll try these and see.
8speed DinoSORAs
The main issue with chains is cleanliness. Regular cleaning + any lubricant that penetrates the chain links & pins and stays there is the way to go. No mechanical system can tolerate excessive contamination.
Once my chain looks grotty (yes a totally subjective term ) - typically every couple of hundred miles or so, it is removed for a good clean. It is replaced and carefully re-lubricated. Yes, it is a pain but:- I built the bike in Dec 2004, new cassette & chain (SRAM PC68). After 2800 miles of use in all weathers, wear on the chain is barely discernable, less than 1/32". Lubrication was castor oil, by the way. I'm pleased with this performance.
Before I knew better, I had chains that measured 1/4" elongation over 12" even though I'd tried various bike specific chain oils from that nice "rack of expensive promises" in the bike shop.
Get a bicycle. You will certainly not regret it, if you live.
Bikes: 05 Specialized"Roubaix" Campy 10spd.
Originally Posted by peripatetic
Wow, that's really condescending. Make friends quickly, do you?
Yes it was and so too was the question and yes I do, thanx fer askin.
It is my belief that every person in this world has something to teach, and everything to learn.
In memory of Jim Price (aka. sydney) ...
Bikes: All 70s and 80s, only steel.
Originally Posted by juicemouse
Me thinks you need to tune your interpretation-of-other-peoples'-comments meter.
More like go out and buy one. Can't tune what you don't have.
I would say that my question was more sarcastic or facetious than condescending, but I guess I'm splitting hairs. Let me be more direct: stv, your comment was derisive and unnecessary.
Bikes: Giant Yukon
Do not use vegatable oil on you bike (including 3-in-1 oil because it is vegatable based). Vegatabel oil becomes very sticky and gummy with time and will cause dirt and grime to build up on your chain.
............. "so tips greatly appreciated"
Lemme see now, how about an advanced degree or doctorate in "Biochemistry", "Biology", "Petrochemical Engineering" or maybe even plain old "Tribology" just for starters.
https://patft.uspto.gov/netacgi/nph-P...&RS=PN/5472625
calcium stearate is easy to come by and vegetable based, paraffin wax could be substituted by soy based wax or beeswax, petrolatum might be replaced by jojoba and/or castor oils, and the volatile solvent could be turps, ethanol, etc.
i'm going to order the ingredients this weekend and make up a several variations soon. anybody have any ideas for non-anecdotal testing?
Really?
I thought my advice to the OP was solid.
I have worked in the technical side of speciality lubricants industry for 25 years now. Our USA operations alone manufacture nearly 70 million pounds of industrial greases a year, not to mention the ten's of millions of gallons of speciality lube oils and other non-automotive products.
......... you can ruin your Mom's food processor or for a $1.79, you can buy yourself a tube of chain lube.
Bikes: '64 Schwinn Traveler, '73 Astra Tour de France, '79 Fuji Gran Tourer, '86 Dahon folder, '94 Specialized Hardrock, '95 GT Timberline, 2005 Jamis Aurora
Some people take the position that lubing a chain does more harm than good: https://www.sheldonbrown.com/chains.html see the first paragraph under "oiling chains"
NOTE: I'm not saying that Sheldon Brown says you shouldn't oil your chain. I am merely offering the link as evidence that others have encountered this school of thought. I oil my chain, and I'm sure that Stv could offer us a whole host of reasons why everyone should oil theirs.
Really?
Originally Posted by mpls
you can get anything 'preassembled,' but that sounds like a pretty sterile life to me. same reason i prefer to build my own wheels and paint my own bikes, personal betterment outside of physical activity - a great hobby biking is.
I don't disagree with your outlook in the least. I admire your initiative and self-reliant independent and creative outlook to your hobby.
However.......................
I read the patent link and I may not understand everything in it but I do understand the complexities of grease saponification and formulating thixotropic lubricants. This isn't "stuff" you just stir-up with a wooden spoon on a hot-plate in the back shed............then again...maybe for some folk ...... it is!
Calcium soaps? ...hydrated or anhydrous? ....stearate or complex? ........ know the difference? Cold grease reformulating vs. heated? Temperature curring and Age setting? Grease/oil separation? Paddle blending?
FYI : Calcium anhydrous grease made from 12-hydroxysterate soap have excellent water-resistant but rust metal easily unless a proper RP package is added in the correct proportions. EP and AW packages? Thickeners? Catalysts? Anti-oxidants? Adjuncts? VI improver's? Double jacket heated kettles?? It just goes on and on.
My point is this, any unadulterated by you, calcium grease that you buy, say in a 14oz. can is most likely going to ALREADY have more than enough lubricant performance that you will ever need and at 14 ounces is most probably enough lube for at least a decade of use or more per bike.
............$1.79 will buy you a fully formulated lube product and then some.
Have fun, good luck and try not to set the kitchen on fire. Please dispose of the experimental grease "goo" safely at an Authorized Community Waste Disposal Site when your done.
.......... and to you two other tyre-biting dogs............. bite this...(!)
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Originally Posted by UCSDbikeAnarchy
Last night, as a was pouring off the excess oil for a tofu fry, I had the same thought...
Althouhg I care about the enviroment, for my own bikes, I'll use whatever works, natural or not. But lately I've been salvaging a lot of beat up weathered bikes with chains that proably should be replaced. Would soaking a rusty chain in vegetable oil help it at all, make it last throuhg winter at least? or should I just throw some cahins into the frying pan and see what happens?
For heavily rusted chains, strong acid may remove the rust, but I won't try it because I would not trust a chain treated with anything that attacks metal such as strong acids and bases. It's better to buy a new inexpensive chain.
Roccobike BF Official Thread Terminator
Or, UCSDBA, you can try soaking the chain in a weak acid: Coke or generic white vinegar. I've used both of these to remove rust from parts, and it works well. I think overnight wouldn't be too long. You may have to scrub the rust off with a steel brush afterwards, though.
...go Tritons...
...go Tritons...
holyrollin'
...go Tritons...
...go Tritons...
IMO this should work well on a chain, but also promote drying within the links somehow. A bit of time in the ol' toaster oven, maybe?
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by alancw3
i have been using a mixture of coconut oil, pineapple juice and rum. my chain seems to always be happy and shift great!
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Originally Posted by FlatTop
I'm using white vinegar right now to clean the rust from some old files and chisels, and a casette. I'm very impressed with how well this works. My use of this method includes soaking and periodically brushing with a bristle brush to speed the process. I follow with a rinse in a baking soda solution to neutralize the weak acid, rinse in plain water, dry, then a spray of thinned oil to give the cleaned tool or part some rust-resistance.
https://www.stovebolt.com/techtips/ru..._derusting.htm
Originally Posted by AndrewP
Cocnut oil will probably turn sticky as it ages and also collect road dust. If you have trouble finding specialized chain lubricants in India, maybe you should try paraffin wax (as used in candles). See the Sheldon Brown article for more info:
https://sheldonbrown.com/chains.html
holyrollin'
Originally Posted by dedhed
If you do this often you may want to check into electrylosis. Works great.
Bikes: Motobecane Le Champion Team, Trek 6700 Custom
Originally Posted by sajikumar
Can I use Coconut Oil or any other vegetable oil (OR Mix of Coconut Oil with other Petroleum products like Kerosine)as a Chain lubricator ? Thanks
