Patching tubes - rubber cement?
Sweetened with Splenda
Bikes: Too many 80s roadbikes!
Is there any real difference between the rubber cement in those little tubes in patch kits and the rubber cement sold in 8-oz jars in the office-supply store?
-chris
-chris
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
I don't think so, but carrying around an 8oz glass jar would be a bit much.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
Originally Posted by brokenrobot
Well, sure. But most of my patching gets done at home, and the big 100-patch boxes of tip-top patches seem like the affordable way to have a lifetime supply - except that they don't come with glue
Quoted: 114 Post(s)
Liked 119 Times
-chris
-chris
Quoted: 113 Post(s)
Liked 16 Times
something that always struck me as odd is that you are supposed to apply the cement and then let it dry before applying the patch. That is what the instructions lead one to believe and I have tried both methods. waiting for the cement to dry makes it much easier and cleaner and it works!! Can anyone explain this to me?
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Originally Posted by cyclotoine
something that always struck me as odd is that you are supposed to apply the cement and then let it dry before applying the patch. Can anyone explain this to me?
Quoted: 2026 Post(s)
Liked 1,096 Times
I've been using Elmer's Rubber Cement with Rema patches (bought by the 100 patch box also) for years with excellent results.
As to the cement in the patch kits being "vulcanizing fluid", that chemically incorrect. It's thin rubber cement, plain and simple. Tubes are already vulcanized. Nothing more is going to happen to them and certainly not at room temperature.
Likes For HillRider:
Quoted: 114 Post(s)
Liked 119 Times
Your experiences with stationary rubber cement trumps my educated guess! Mudpie stands corrected.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
What is this Monkey Grip of which you speak?
https://www.victorautomotive.net/pages/
Bob
Likes For Bobby Lex:
Dave
Bikes: Nashbar X-Cross 29r wheels front disc brake
""I actually go one step further. I cut patches out of an old tube and glue them with rubber cement.
Bob""
That is frugality at its finest! I will never throw an innertube away again. Thanks for the tip.
Bob""
Liked 1,096 Times
Saving money is just a nice side effect.
Quoted: 1572 Post(s)
Liked 643 Times
Those little tubes of cement that come with patch kits seem to dry out overnight and are worthless by the time I need them again.
Bikes: Giant OCR Touring, Raleigh Sport Comfort, Cannondale ST400, Cannondale Road Bike
I do, though, usually keep some of the thick patches for kids on the bike path when they have a flat on their xmart bike. (I get to promote helmet safety while patching their flat.)
Originally Posted by librarian
To save a little money, buy some patch kits at the dollar store. Throw away the thick patches and keep the glue. HillRider is right about it drying in the tube right away. I only get to use it once, that's why I don't buy it at the bike store for three dollars.
Yeah, it's the dollar-store patches that have finally driven me to try to track down a box of tip-tops
weirdo
Bikes: Viner Pro Carbon,Fat Chance Yo-Eddie, Specialized S-Works (epic), Voodoo Rada, Trek 830 setup SS for commuting.
Ok, the cutting out the old tube thing... Are you actually cutting out ould patches, or just using rubber cement to glue pieces of an old tube to the one you are trying to repiar. I only ask because I am the cheapest person on the face of the earth and don't want to waste my rubber cement trying the wrong thing.
I think they're gluing bits of old tubes to repairable tubes. I've done it myself, but ultimately decided it was worth buying patches... If you DO try it, be sure to sand both surfaces thoroughly - tubes are coated with a release agent to get them out of the molds they're made in, and if you don't get all of it off both pieces, nothing's going to stick well...
Drive the Bicycle.
Bikes: Three-speed modified for comfort.
"The bicycle is the perfect transducer to match man's metabolic energy to the impedance of locomotion. Equipped with this tool, man outstrips the efficiency of not only all machines but all other animals as well." Ivan Illich ('Energy and Equity')1974
2. Take a box-cutter and a straight edge and cut a dozen or so patches out of the old tube.
3. Clean each patch with rubbing alcohol.
4. Clean tube with rubbing alcohol.
5. apply rubber cement to both surfaces and let semi-dry.
6. apply patch and clamp overnight. (I typically place a small piece of wax paper on top of the patch and then put something heavy on top of the tube to hold the patch in place while curing).
Obviously this is a complicated repair that is not intended to be done on the road. If I flat on the road, I replace my tube, saving the old one for repair on my workbench at home.
Bob
sorry for the out of date bump on this thread...someone else linked to it, and it make me think of the below..
another way to save on rubber cement costs, especially if you have other mechanics pulling from the same jar of glue, is to get two jars of rubber cement. one is huge, and lives in a closet. this one is only used to refill the second, smaller one that lives near the bench. if the top gets left off the smaller, benchtop tub, then you've only wasted that small amount of glue.
of course, if you have trouble remembering to tighten the lid on your backstock jar, i can't help you.
Well, my use of office supply rubber cement isn't intended to save money but to insure I always have useable rubber cement when I need to patch a tube. Those little tubes of cement that come with patch kits seem to dry out overnight and are worthless by the time I need them again.
rubber cement types
It happens that I tried the rubber glue from office supply source a d it did in deed wreck the integrity of the tube. It literally made the tube useless.
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
I have a supply of Rema patches and an 8oz can of Rema vulcanizing fluid. More expensive than rubber cement or cutting pieces from an old tube but I get a lot of peace of mind .
Likes For robert schlatte:
