Long front brake bolt
Old 01-27-06 | 04:41 PM
frogman_94's Avatar
Old Frog
Bikes: Cannondale 613
I putting together my new bike and I discovered the front brake nut is too short to fit through my carbon fiber fork. I have Campy Record brakes. I looked in the specs and found out that Campy makes a longer nut. The part number is BR-RE427. Can anyone tell me where I can get one? For now I bought a longer one but it's a cheap steel one. I would like to get an original Campy titanium one.
frogman_94 is offline
Reply
Old 01-28-06 | 05:26 AM
I had the same problem when I replaced my fork with a new, wider one. My LBS had a longer nut in stock.
Bob
Bobby Lex is offline
Reply
Old 01-28-06 | 06:16 AM
cascade168's Avatar
Klaatu barada nikto
You should contact Peter Chisholm at:
https://vecchios.com/index.html
There is a phone # and email link for him on that page. If anyone can help you, it's him.
cascade168 is offline
Reply
Old 01-28-06 | 09:47 AM
Check your LBS as they are likely to have these in stock. Many carbon forks have thicker crowns than steel forks and require a longer brake mounting nut. Dealers are used to the problem when the do upgrades.
My Kestrel EMS Pro fork came with the longer nut and explicit instructions that it had to be used.
HillRider is offline
Reply
Old 02-15-06 | 05:36 PM
frogman_94's Avatar
Old Frog
I ask my LBS about getting a Campy nut. They called the Campy rep and he never had anyone ask for that part before. I guess they use the steel problem solvers to put their bike together.
Reply
Old 02-15-06 | 08:02 PM
concernicus's Avatar
Bikes: doesnt matter. just ride.
you can get one on the web from loose screws
concernicus is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
