Dump the hollow axle?
Location: Home (don't change this back to "my own personal hell", Mr. Powermad Moderator, and/or computer savvy hacker).
I have a new Odyssey Hazard Lite wheelset (flip-flop rear axle) en route. Since ordering I've heard of problems with the rear hollow axles...
I weight 200 lbs & like to jump (street & trails)... Should I buy a solid rear axle?
member
Bikes: Solid AA
Do you run pegs? No? Then it won't be a problem. And hollow axles have a better strength:ratio than solid axles, anyway.
Thanks!
BTW, it's beer:30!
That sucks...
My 1st beer's dedicated to you...
"Uh-uh. Respek Knuckles."
Bikes: '06 LeMond Versailles, '04 S&M Beringer, '03 Quamen Bowls, '68 Raleigh Grand Prix (converted to fixed gear)
Run what you have until it breaks, then re-evaluate.
I'm trying to build a bike that wont break anything in the near future.
member
Bikes: Solid AA
Your only other real option is to just use a 10mm-14mm conversion kit, which is basically a hat washer with a 10mm (3/8") inner diameter and a 14mm outer diameter.
Originally Posted by hypersnazz
Unless it does nothing more than sit in your garage and occasionally take you to 7-Eleven, you will probably fail. And unless you're already breaking axles there's no reason to assume you're going to, especially if it means throwing away a perfectly good hollow axle in favor of a solid one.
They don't sell solid flip-flop axles anymore.
