Rusty Nuts!!
Rusty Nuts!!
OK... it's really rusty bolts, stem bolts that is, but the title sounds funnier!!
Since I've been riding all winter in Chicago, my stem bolts have a nice coat of rust on them. What's the best way to clean this up and furthermore, prevent this from happenning again?
Thanks!
Thanks!
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Another strategy is to replace the rusting bolts and nuts with stainless hardware. However, the stainless steel is somewhat weaker than the typical steel in screws. If I were to replace my single stem-clamp screw with stainless, it would break.
use a little steel wool to clean them off... then dip your allen key in grease (i use swiss bearing grease) then shove the allen key into the bolt as to cover it with a little grease. it works
good luck
good luck
Quoted: 840 Post(s)
Liked 336 Times
There are plastic caps around, specifically dedicated for covering the stem bolts, but they get easily lost. You can fill the slots, though, with wax, obtainable at a hardware store, if you want to prevent water from accumulating there.
Bikes: what's a bike?
use wd-40, but not on the drive train, think about chenging the bolts to aluminum or stainless
Year-round cyclist
My solution:
- WD40 sprayed occasionnally onto bolts that I can touch (i.e. it's fairly clean).
- Oil or grease is used onto bolts that I can't touch (i.e. it last longer).
Bikes: 1998 Specialized Hardrock Classic, 1999 Gary Fisher Marlin, Surly Karate Monkey
What do you do when you have rusty nuts? Egads, methinks you consume too much iron, and you need to wear something to stop chafing that area, thus exposing your blood capillaries to the oxygenated air...
OH!
You mean THOSE rusty nuts! I thought you meant... ahh, um, anyway, just scrub em down and use some silicone.... eh, my mind's in the gutter today....
OH!
Bikes: Bros Sonic FS XT-LX hybrid w/Brooks Swift
I have had success with colorless Tectyl (anti-rust treatment for cars). I soak a cotton stick and apply inside allen heads etc. No more rust, even if I use the bike in the salty slush.
Erling.
Erling.
Sensible shoes.
Bikes: A few.
I hose the whole works in WD-40 regularly during the slop/salt season. It's working like a charm. This B.S. about it doing horrible things is just that. Just don't rely it as a quality lubricant where one is needed.
