Wheelsmith AE15 spokes
Has anyone had long term experience with these? They are light and aero... and a lot cheaper than other aero spokes... at least in the US.
https://oddsandendos.safeshopper.com/20/83.htm?389
The Red Lantern
They are barely aero, in my opinion. They will fit thru a standard drilled hub so the aero profile has to be pretty minimal, so the benefit has to be pretty minimal. The XL 14 is just as light, about the same price and won't have as much twist up issue when building them.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Hoosier Pedaler
Twist was not a problem at all when I used these spokes... it is very easy to see and correct for, unlike round spokes. I *did* oil the threads though...
The Red Lantern
OK. First you ask if we have used these spokes. Then just a few hours later you tell us how great they are, listing a website both times. You have only made four posts and three of them talk about these spokes and mention the website. This looks a lot like advertising(The blue star means moderator) which is only allowed for supporting members and then only in the for sale sections, see the bar at the top of the page..
I am a pro builder that has been doing it for twelve years now. Built lots of aero blade wheels, used to do it for a big trishop that exported to Brazil. Yes there is a gain for bladed spokes under certain conditions, like long flat rides with no side wind. These were deep blade spokes that required slotting the hubs. There may be a slight gain from the AE15 when in a radial build to get the most benefit from the spokes trailing each others slipstream. In real world, I see no benefit from using them over a traditional butted spoke that will have a nicer spring to the ride and often cost less.
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
I particularly like that the oval profile permits you to be certan that there's no residual twist in the spokes...this is a chronic problem with round-section lightweight spokes.
Sheldon "Thumbs Up" Brown
Code:
+---------------------------------------------+ | Television: | | A medium. So called because it is | | neither rare nor well done. | | --Ernie Kovacs | +---------------------------------------------+
OK. First you ask if we have used these spokes. Then just a few hours later you tell us how great they are, listing a website both times. You have only made four posts and three of them talk about these spokes and mention the website. This looks a lot like advertising (The blue star means moderator) which is only allowed for supporting members and then only in the for sale sections, see the bar at the top of the page..
I did list that website and mention these spokes 2 weeks ago... not a few hours ago. Thanks for reminding me about that... I'd totally forgotten. I haven't posted here very much, but I've posted on other cycling forums several hundred times since last summer. If I was advertising, it would have to be for Mike Garcia (who I did not mention, but plenty of people here do), or Wheelsmith... and I doubt either of them really cares if anybody buys AE15s or not, since I'm sure the profits and margins are bigger on the XE14's... which appear to be the same except for 2.0mm ends, and cost over twice as much...
I used AE15s a long time ago when they were the only spokes of that type. I liked them... never broke any. After a 10 year layoff I just started cycling again last year... and noticed that CX-rays were all the rage and cost a fortune... but for some reason AE15s at 1/3 the price are relatively unknown. I bought some recently and respoked some cheap wheels I had, but I became curious to know if there was really some good *reason* why they weren't being used that much... like maybe they were junk. Hence, my post enquiring about other's experiences.
Numerous wind tunnel tests and field tests indicate that there is a small but significant benefit to aero oval spokes... important if you are competitive. If I had loads of money I'd buy CX-rays, which are widely touted as the strongest (in fatigue), lightest, most aero (yes, all three) spokes you can buy... but I'm not advertising for them either.
BTW, I used to be an engineer before I discovered freedom by sliding much lower on the socio-economic scale... and of course I know that doesn't mean I know anything about wheels or spokes...
Originally Posted by Sheldon Brown
I like 'em a lot, they're my favorite spoke for fancy wheels. I don't generally use 'em on the right rear though, DT 2.0/1.8 is my usual choice for that.
So... your customers have been happy with them? No strange breakages or quality problems?
The Red Lantern
If you want an aero spoke that does not require slotting the hub, then they are a good choice. And they are good spokes. But, I think that for most wheel builds a butted 14/15 will be more durable and give a better ride. I am not an engineer but as I understand it a cylinder is stronger than a flat bar of the same mass. The other issue is that aero spokes are a disadvantage in a cross wind. Even the narrow section of the AE will have noticeable "push".
IF I were building a racy wheel for someone, unless they wanted an aero spoke, I would use something like a revolution, to drop the weight and they are so thin the profile would have little negative effect either in the spoke slicing thru the air with the spinning wheel or from crosswind. They also have a nice give and offer a good ride.
In truth I don't build that many road wheels other than track any more, most to the stuff I do is for MTB or freeriders, and they are more concerned with durability.
Do you do anything minimize or account for twist when you use Revolutions or similar spokes? I used 2.0/1.7 spokes on the drive side, and I was more worried about twist there than the AE15s because I couldn't *see* it. Maybe marking with a pen would be a good idea...
The Red Lantern
I stress relieve the heck out of wheels when I build them and it keeps them from winding up.
A light guy can get away with a 1.8 j-hook. But Every low mileage failure I see is with the 1.8 j-hook spokes. I think the failure rate is not just because the spoke is thinner but because the hubs are drilled for a good fit with a 2.0 spoke. The spoke has less contact esp when the holes in the hub are not radiused.
