Short bike for short person...
Bikes: Trek 100c, Specialized Rockhopper
Hello to all. I've been watching this forum for a while and enjoy all the info you've given to people in the past. I've learned alot just by reading. Here's my first post and I hope you can help.
Here's my problem and I can't fix it. I'm 5 ft 2in tall on a good day. I cannot seem to find a bike for loaded touring that will fit my really short legs (281/2 in inseam). I can't afford to go with a complete custom like a Miyata or Co-motion because I've got three kids, a house with a mortgage, and bills. I bet you can relate.
Anyway, two years ago I bought a Trek 1000c. It was in my price range and at the time I didn't really know what kind of riding I would be doing. I expected a trip around the block or weekends on a rail trail would be the most of my riding. Well, last summer, I did my first tour and I positively love it! I'm looking to do some more this summer. Maybe the C&O then around Washington DC or maybe around Grand Teton and Yellowstone.....
OK, OK back to the bike issues, the "c" in 1000c stands for compact but this bike wasn't "compact" enough. I've changed the headset and stem to make the bike as short as I can and the bike is comfortable but not "ride all day" fun. I also changed the crummy gearing to a Shimano XT 22/32/44 but when the front derailleur was installed the seat tube got bent. I'm just not comfortable travelling miles and miles on an aluminum frame with a big dent in it. There have been so many changes on this bike to try to make it fit the only thing that is original are the brakes. I would like to find a bike that I would really like to ride around on for the rest of my life. I've researched this for a long time and every large manufacturer of touring bikes make them way too big. I'm not interested in Terry-- I don't want to go through another component "changeathon" because the larger companies won't lower their gearing for loaded touring.
The two bikes that I have been able to find that should fit and work for loaded touring are Bruce Gordon's BLTx and the Surly LHT. First, how do I figure out if the components that are on my currrent bike will fit on the LHT? That would be my first choice. Second, how do I know if there will be enough clearance for my heels once the panniers are on? I used a trailer with the current bike and would like to have the option for bags or a trailer depending on the trip. If you have any other ideas, I would really like to hear them too!
I appreciate any info you all may have. Thanks for your time.
Year-round cyclist
Your components should fit, with a few exceptions.
Bruce Gordon (assuming you buy just the frame & fork, rather than the complete bike) is using a threaded headset, which means that the threadless stem you have on your Trek 1000c won't fit. If you use a stem for 26.0 mm handlebars, you should be able to use yours.
With either the Bruce Gordon or the LHT, you may need a different front derailleur because the seattube will be smaller than what you have on your 1000c. Your current one won't clamp properly. You may also need a bottom bracket of a different length than what you have right now; no idea about that.
If they fit, some other touring bikes might be interesting. If you get at them on a good day, many bike shops might be interested in swapping chainrings or the crankset at the time of purchase. However, unless you love toe clip overlap, you should stick with 26" wheels.
As for heels vs panniers, the common wisdom is that the added 1-2 cm chainstay length should make all the difference. But many people have no problems with panniers on a Trek 1000c (or similar); they simply move them back on the rack.
Hi Sarah!
Welcome to the Touring forum - good choice! First of all - with a 28.5" inseam your legs aren't that short at all. In fact, for your height I think you probably have fairly long legs and a shorter torso, hence your fit problem. Many women have trouble with the reach to the bars, so look closely at top tube length relative to the seat tube length (frame size). I am 5'10 and have 31" inseam, and I ride 54cm or 21" bikes and prefer Trek models partly because they seem do not stretch me out too much. I can't imagine that a 17" Trek 520 would not also work well for you, although the benefit of an LHT would be that it has 26" wheels in the smaller frame sizes, which keeps the geometry from getting too weird. It is a really nice bike and there are lots of nice pics of them on this forum. Any good steel bike will also ride better than your Trek 1000 aluminum.
I'm not sure which components you want to swap over - the crankset? That would be useable on the Trek 520, on an LHT, etc as they can all take a mtn crankset. The BLT will come with that setup. I do not think you will have a problem with heel clearance as most of the touring frames do not diminish the chainstay length much in the smaller sizes. Your feet are undoubtedly smaller so I don't think there will be an issue.
Good luck and good touring!
john
john
Quoted: 12190 Post(s)
Liked 1,495 Times
Huh,
my wife is 5' 2". She wound up with a Bianchi Strada. Her choice, not mine. I would suggest sticking with 26 inch wheels. You get better geometry.
That and your budget makes the LHT a leading candidate. But there may be a problem. You have longish legs for your size. Which means your torso is shorter than typical? I wonder if you are going to be comfy on a 53cm top tube.
To get a shorter top tube you might have to jump down to 46cm.
Which might feel small. I suggest trying before buying. Yeah, I know that is prob not possible, but call around. At the very least find a bike with a 53cm top tube and try that.
The Rock Cycle
First off, don't worry about heel clearance. The chainstays are very long! I have fenders on my bike, and I can still fit my Road Morph pump behind the seat tube.
I do have a bit of toe overlap with the front wheel, but it hasn't really been a problem so far and I haven't worried about it.
I left the steer tube long on my LHT so I have a more upright ride. It's not a lightweight dainty bike, but it doesn't care what you strap on it or where you point it. I have not toured on mine yet, but I have employed it to carry stuff around town.
Let me know if I can answer any specific questions about my bike, if you have any.
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Motobecane Fantom CXX
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
The Rock Cycle
Originally Posted by mtnroads
Hi Sarah!
john
john
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
The Rock Cycle
Pics of my LHT (and my Pacer)
https://community.webshots.com/album/82565251NmJWKQ
My LHT now has XT mtn bike cranks on it instead of the 105 road cranks in the pics. tinker...tinker...
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Liked 1,495 Times
like that.
Quoted: 19 Post(s)
Liked 7 Times
If you are on the short size, then 26" wheels make sense. Short cranks will fit your legs better and will reduce the possibility of toe-clip overlap and pannier-heel interference.
The Rock Cycle
Originally Posted by late
Nice bikes. Tell me, how do you like the Pacer? I'd like to get my wife on something
like that.
like that.
I have another Pacer frame here. I'd tried to sell it, but got no bites. So I decided to build it and ride it, since I like the frame so much. This one will be a commuter-type bike I can lock up. Going to put some stuff we already have on it, plus I'm going to try out some Nashbar brakes and pedals. I have a set of 165mm Sugino trekking cranks on order. I'm going to put on 700x28 tires and fenders, dt shifters, etc.
BTW, for folks looking for cranks with 165mm arms, which are hard to find in Shimano, I see that Sugino makes several models in that length. The prices seem reasonable too. I hope they work out nice for me. Anyone have experience with Sugino cranks?
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
I love love LOVE! my Pacer. It's not light and fast, but it's such a stable and comfortable ride. I've done many long rides (century), and long climbs. I have 9sp Ult and XT on mine, with a lowest gear of 30-34. We have a few hills here in CO. I like to climb.
About Suginos - between my wife and I, we have had 5 Sugino cranksets, and they are great deals. They are also 110/74 BCD, which allows a nice range of chainrings as well. They look good, too, but it's more important that they are dependable and strong.
I'm Carbon Curious
I face a similar problem since my inseam is supa short 27.0in and I'm 5'4. I agree with previous posters that the geometry of a bike with 26in wheels will provide better handling for smaller folks like us
The problem for me though with 26" wheels is the tire selections.
I only ride specialized armadillos tires and the smallest width tire is 26 x 1.25". Still too fat for my short distance touring needs. If they made an armadillo at 26 x 1.0 or even thinner, I'll sell all of my 700c bikes and get 26" bikes, but I can't because I'm too use to nice fast and thin 700 x 23s.
That's why even though I'm short 5'4 and should ride 26" wheel, I'm sticking with 700c tires. I know the original poster said that she wanted to do loading touring which is perfect for fat old 26" tires, but anything faster like credit card touring, I'm going to stay with 700c.
Liked 1,495 Times
I have a Sugino crank, nice for the money. I think you'll
like it. I'd avoid the steel rings because they're so heavy.
Greetings and thanks go out to all for your help!
I'm amazed at the number of replys! It sounds like the votes are going for the LHT. I have to admit hearing you all say I have long legs makes my heart smile just a little bit more. At least something on this short little thing called a body is considered normal! It's also nice to know my problem in bicycle sizing is in the torso.
Here's what I'm considering and please let me know if it's a good or really bad idea. I would like to go with the 42cm LHT which has an eff TT of 50.5 vs 52.4 for the 1000c (the 46 LHT is too tall and the Trek 520 TT is 54cm).
Mtnrds you asked what I wanted to swap and the answer is "as much as possible". Everything is basically new so I would really like to use it. I had some one-on-one time with my 1000c bike and made a list of everything that I'd swap if possible. If you're willing to be my guru's I would appreciate the feedback.
LX crankset 175 (these are listed for MTBs)
Ultegra Derailleur (sorry I lied about what I thought I had)
Sora Shifters (it's the one thing I liked with the setup)
XT Rear derailleur
11/32 freewheel
Truvativ hussefelt stem
bars
headset
I want to get new brakes and tires.
I love the pics of your bike eofelis. I wasn't sure about the sage green color of the HLT but seeing it in the sunshine really makes me like it. Did you order the frame from Surly or from somewhere else? What do you like about it and what do you not like about it? If you got it from Surly, were the people good to work with and how long did it take for it to arrive?
Thank you again for the help. It's just great to have some info.
SarahJ
XT Rear derailleur
11/32 freewheel
bars
headset
SarahJ
You're right, of course. The options are limited. But, personally, I would rather sacrifice super narrow tires first, ideal geometry and fender-toe clearance second, for a touring bike.
The Rock Cycle
XT Rear derailleur
11/32 freewheel
bars
headset
SarahJ
XT Rear derailleur
11/32 freewheel
bars
headset
SarahJ
I put everything but the wheels, headset (520 is 1", LHT is 1 1/8") and the front der from the 520 to the LHT. I don't know a whole lot about just what fits what, but use everything you can.
I really liked the sage green and I didn't want to wait for the new colors. I got mine from a local bike shop. Any bike shop that orders from Quality Bike Products (most do...?) can get a Surly for you. I've also heard chatter about folks ordering them online from some shop like Spicer Bikes (google search) for a good price. They run around $400 for frame and fork. We have 3 Surly bikes in our family, soon a 4th. A great frame for the money!
The only thing I though was a bit strange on my LHT was the placement of the water bottle cages. They are placed so high on the frame that I have to use smaller bottles or a side entry cage. Otherwise it's a *very* solid ride. But mind you, it's not a light bike. I think mine weighs more than my mtn bike.
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Year-round cyclist
Eofelis,
If I were in your shoes, I would probably remove the side-entry cage and use a regular cage on the seattube. Just use the bottom bolt braze-on for the top bolt and a zip tie at the bottom end of the cage.
I had installed such a cage on my daughter's bike, but the bottle didn't survive more than 1 km of potholes.
Another note: The Trek 520 used a 1" threaded headset until model year 2000 (inclusive), but shifted to 1 1/8" threadless (like your LHT) in 2001.
The Rock Cycle
Originally Posted by Michel Gagnon
Eofelis,
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Gunnar Sport
Specialized Ruby
Salsa Vaya Ti
Novara Randonee x2
Jamis Dakar XCR
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
Eofelis,
Stuart Black
Stuart Black
Liked 4,213 Times
XT Rear derailleur
11/32 freewheel
bars
headset
XT Rear derailleur
11/32 freewheel
bars
headset
Some things to consider as you work on building the bike.
1. A crank that is 175 mm long is properly sized for me, a 6' tall man, to ride for mountain biking where leverage is needed at low rpm, high torque situations. In lower torque, higher rpm riding, a 170 mm long crank is better for me. For you, a 175 mm crank makes no sense whatsoever. If you can replace it with a 165 mm crank (160 would be better but nearly impossible to find).
2. Think about new bars, unless the ones you currently have are narrow. Most bike come with bars that are too wide for your shoulders. A narrow bar for a narrow shouldered woman may be more comfortable. I ride a 44 cm bar. You might try a 38 cm bar.
3. Stem. The stem you have is for DH mountain biking. You probably have it because it's one of the shorter ones you could find but it is way overbuilt (heavy) for what you are using it for. Look for a lighter weight short stem. Truvativ makes some road stems (and mountain bike stems) that are 60mm long. There are others but they may be hard to find.
4. Headset. Go with threadless if you can. They are easier to set up and, if you what to change stems and/or bars to find the right size, they are easier to change. Also cut the fork extra long since you can always take some off the stem but it's tough to add it back on
5. Local bike shop. Last but not least, find a local shop that you can develop a relationship with. For people of your size, bike parts that fit properly aren't usually carried in stock. The parts are available but you will probably never find them in the bargain bin at your local shop. This means that you will probably never get to buy parts on sale, especially critical parts to make the bike fit better. You can do the work yourself but getting the parts is going to be tough!
Good luck.
Stuart Black
Stuart Black
In planning
Bikes: Revell custom tourer,Kona Stinky,Omega TI,Gaint TCR,Simonchinni,Raliegh ti,S&M Next Gen.
I'm a 5'4" short ass guy I've always apart from a few bikes gone for custom frame as you'll always struggle to get a frame that fits. The thing that bugs me with off the peg frames is who at my hieght has almost the same reach as some one 5'7" apart from a monkey, I've aways wonder why i need a 52 cm or even as long as 53 cm top tube when I've always found a 50 cm is more like it, and just about every one that's about my hieght that has ridden my bikes comment on how comfortabile the reach is and how well the ride. Custom frame needn't be expensive as you can have them made out of matrial at your budget,also keep an eye open for us vertically challenge ones selling our bikes off. If your not sure what size frame you need find a freindly bike builder (don't go to you local bike shop who sell off the peg frames as they'll try to sell you anything to make a sale, unless they're a true specialist shop) and ask him to measure you up for a frame even if you don't intend buying offer him some money for his time, and if you like the service go back later when you've got some cash and buy a bike from him.
Year-round cyclist
We had 2002 and 2003 year Trek 520s, bought new, both rainforest green, both same component set, in our fleet, both were 1" threadless headsets.
Sorry Madam, I must have missed one "generation" of threadless headsets.
