Setback post forwards?
Old 11-11-02, 06:43 PM
Apot.
sshock4's Avatar
Can i turn around a setback post so that it is basically set forwards? Or will that mess up the goemetry too much?
Thanks
sshock4 is offline
Old 11-11-02, 06:49 PM
Just ride.
roadbuzz's Avatar
Boy, it would for me. Whether you can do it or not depends on the post... there's a lot of variety.
The question in mind is 'what problem are you trying to solve?'
roadbuzz is offline
Old 11-11-02, 07:21 PM
Apot.
sshock4's Avatar
There are two possible types, one being where it bends back then straightens again to take the same angle, and two ebing where it just bends. I am suspecting the former would work better.
The problem i am having is that i just bought a large Ellsworth Joker frame which is the right heigt for me, but a little too long feeling. I am going to get a very short dh stem but was wondering if i could also fix the problem with a setback post.
By the way is it possible to turn a stem backwards?
sshock4 is offline
Old 11-11-02, 07:37 PM
RacerX's Avatar
The only people that do that is triatheletes. They flip setback posts around so that they can save their running muscles.
For any other type of riding, it will mess up your pedal stroke. Also, it puts so much weight on the front wheel that it is dangerous for anything other than time trials.
RacerX is offline
Old 11-11-02, 07:41 PM
Apot.
sshock4's Avatar
Thanks. I was suspecting that it would mess something up but i wanted to make sure because i think there is a thompson setback on mtbr for sale.
sshock4 is offline
Old 11-12-02, 04:20 AM
Plays well with others.
greg360's Avatar
ssshock4, I'm also looking to get a setback seatpost.
You might want to check out the reviews of that model Thompson seatpost from roadbikereview.com
https://www.roadbikereview.com/Seatpo...7_2510crx.aspx
From what the reviewers are saying, you can angle the post forward or aft, but get mixed results (depending on who you ask) either way.
Here's another seat post that with adjustable fwd/aft positioning
https://www.roadbikereview.com/Seatpo...8_2510crx.aspx
The critics hate it, but you might find it suited for your situation.
It's too short for me (255mm), so I'm still looking for a post with fwd/aft adjustment and a longer (like 300mm?) stem.
Both posts can be had on EBay for about $80.
Anybody got any suggestions on other models/vendors?
greg360 is offline
Old 11-12-02, 11:44 AM
Just ride.
roadbuzz's Avatar
How much setback is there on the post you have? If there's much, reversing the post would probably be too much. Would a post w/little or no setback, e.g. something like this, work?
roadbuzz is offline
Old 11-14-02, 11:33 AM
Bikes: 97 thin blue line rigid mtb, mid 80s norco monterey sl, gave away the rest recently
Did you just ask if you can put your stem backwards? God, how much too long is that frame! While you physically could do it, it would take *some* getting used to. If you look at pictures of really old bikes and hobyyhorses, alot of them were setup like that. But it seems like there are many reasons to not do it. One issue would be front traction. When you stand you wouldn't be able to get as much weight over it. Think more front wheel washouts. I can't help but think it would affect the rake of the wheel. Or maybe that just has to do with the headtube and fork shape. Backwards stem... crazy talk. Try it!
Balance
Balance is offline
Old 11-14-02, 06:41 PM
Licensed Bike Geek
Davet's Avatar
Bikes: Look 585, Kirk Terraplane, Serotta Ottrott, Spectrum Super Custom, Hampsten Carbon Leger Tournesol
Quoted: 92 Post(s)
Liked 69 Times in 48 Posts
One reason that you can't reverse a setback seatpost is that there will not be enough tilt adjustment to bring the seat back to level. The nose will be too high when you run out of adjustment.
Davet is offline
Old 01-06-03, 12:39 AM
Still on two wheels!
I turned my seat post around Saturday because I just couldn't quite get my saddle far enough forward. It has just enough adjustment to get the saddle level and it feels great! The bike is a 56 cm most measurement systems recomended a 54 but the LBS suggested a 56. I noticed that I was having trouble with my achelies tendon hurting. I lowered the saddel and moved it as far forward as possible. I also realigned my shoe cleats. The saddle has very short rails and doesn't afford a lot of adjustments.
Did the larger frame cause the slight missalignment of saddle? Should I have gone with a 54 and used an even longer stem, I'm using 120 mm now,? Should I replace the post with one with no sit back? It also feels much better on my hands now and my knees are in a better position.
uciflylow is offline
Old 01-06-03, 08:39 AM
Greg's Avatar
This was my first thought also. Mabey find one longer bolt?
Make sure the adusting bolts (as found on the Thompson) have a good amount of thread in the cylinder nuts. Wouldn't want it to break apart under load.
Greg is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
