front hub BB help
Bikes: many
the front hub on my mongoose wheel, it is missing a couple BB's, now i have BB's that are a tiny bit smaller then the ones in there, what will happen if i put them in there. Do i just make sure it spins freely and has no free play? or this is a bad idea
P.S. the BB's are metal
Riding is Praying
Bikes: Jamis Nova, Fisher Tassajara, Indy Fab Crown Jewel; Titan NOS fixed
Give it a shot I suppose, but I doubt you will be able to get all of the play out of the hub. Even it it does work I would still get the right size as soon as you can. Good luck.
Bikes: many
Quoted: 2026 Post(s)
Liked 1,096 Times
Use the correct size bearings. Front hubs almost all use either 10 or 11 in each side 3/16" diameter balls and these are easily available at bike shops or auto parts stores. Using a couple of undersize balls will put an excess load on the remaining correct ones and damage the hub rather quickly.
Bikes: many
Quoted: 3450 Post(s)
Liked 420 Times
Originally Posted by russiankdi
i replaced all of them with the same size, which is a bit smaller
The bearing surfaces are machined/sized for certain sized ball bearings and using the wrong sized ones will place loads on the bearing surfaces they weren't mean't to take and I'm supprised you could adjust the cones properly. Replace with the correct size as soon as you can.
Regards, Anthony
Bikes: many
Originally Posted by AnthonyG
How did you manage that?
Regards, Anthony
Regards, Anthony
Liked 1,096 Times
The correct size bearings are cheap and readily available. Use them. It will be a lot cheaper than replacing the hub. A "tad bit smaller" is not good enough.
Quoted: 1572 Post(s)
Liked 643 Times
Bikes: many
well i found the other 4 BB's that i needed. they were in teh hub, and the hub was dirty so i didnt see them, i greased everything up and everything is good now. thanks for the help guys
