Bike Building Tools
Bike Building Tools
I plant to build up a MTB frame in the next month or so. I have plenty of mechanic's tools, but do I need any special tools for installing components. I plan to use Shimano XT components, hydraulic brakes, etc. Thanks,
Lost in the Black Hills
crank puller cwp-6
cassette/ freewheel remover fr-5g
bottom bracket tool bbt-2
chain whip sr-2
saw guide sg-6
spoke tension meter tm-1
wheel truing stand ts-8
double-ended cone wrench dcw-1, -2, and -3 (these are cheap..i would get all three sizes because you never know when you might need a NARROW wrench
spoke wrench similar to this
chain tool ct-5
Tomac Mountain Bikes | Light-Bikes l Magura USA | Industry Nine | Schwalbe Tires | Caffélatex
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
Cable cutters are nice. You'll definitely need cone wrenches.
oh yeah, recently i got one of these:
brs-50r
and one of these for when i wash my bike:
aztec/ delta matisse stand
brs-50r
Originally Posted by MattP.
I would buy a set.
yeah a set might work too...
'Mizer Cats are INSANE
Bikes: C-dale T800
I'm going to risk the wrath of the group and suggest that you might want to look at something like Nashbar Bigger than Big Kit Not up to the quality of Park tools of course, but perfectly serviceable for what you need. You can always upgrade as required. If it's the external BB crank, you will need an external BB Tool, again, I've got a Nashbar and it works just fine.
Yes, top quality tools are great. Cheap tools are junk. The Nashbar falls into the middle, not the best but more than good enough for most home users I suspect.
Just my .02
Steve W
Just my .02
Steve W
Thanks for the tips on tool mfrs. Believe I will order a couple of items including a stand. I see where component mfrs recommend facing some of the tubing surfaces where BB bracket, head tube bearings, and even calipers are mounted. Those tools are quite expensive for an individual to own. How would you suggest locating a local bike builder that would assist in setting up some of the components, someone that may have the correct tools and abilities to use them properly? I am not purchasing my frame locally, so I am sort of hestitant to ask any local dealers for assitance? I know its a great benefit dealing with a local proprietor with any type of product you have when you need help.
the caliper tabs definitely don't worry about unless there is a problem. a caliper is easily removed after the fact and can be faced later. my Hopes worked fine with no facing of tabs.
for the other two surfaces, you can take a flat fine cut metal file and gently span the circular surfaces of the BB and HT. do this gently to mostly just take the paint off. take no to barely any metal off. just light pressure and you will see the paint being removed and the metal getting "shiny" or changing color. you know what i mean. this is a cheap alternative to true facing.
Obeying Gravity
Originally Posted by mx_599
hey MattP...what up!!!
Yeah, for your needs, I would buy a set. If you were to buy individual tools down the road when you come across the need for them, a set might not be the best way to go, since you could wait for deals and what not.
But since you are doing a build all at once, a set might be the best way to go. Check out Nashbar's stuff, or if you want stuff that won't fail, check out Park. And a stand is always a bonus
Bikes: Parlee Z4, Storck C1.1
Performance Bike has their Spin Doctor tools really cheap. As stated above, the tools to get from them are the drivetrain combo (chain whip, cassette removal tool, and chain pin tool), a crank puller and BB tool for whatever type you have. That will get you going into just about anything other than wheel truing and building stuff. As far as the wrenches, I dont need any for my bike, so you may want to save that for picking up as needed from LBS. Go with the Performance Spin Doctor stuff as it is alot cheaper than Park.
to the OP. i am totally for cheaper tools. i am used to buying auto tools, so PARK seemed cheap to me. however, some of those park tools i showed you above were really not that much money. Choose wisely and you can save too. for instance, that little crank puller does ISIS or square or you could buy more expensive ones with a handle....but the one i got you just us an adjustable wrench.
the only expensive things were my wheel building stuff...oh, and i kind of splurged on my chain whip....and the saw guide.
but everything else is reasonable...promise
