Removing aerobar shifters
I am replacing existing aerobars on a tri-bike with new. How do I loosen the shifter cable(other than @ the derailler) and then remove the shifter?
I am replacing Syntace C2 clip ons with Profile T2s. Have Dura-Ace bar end shifters to remove and reinstall. I saw (awhile back) the mechanic @ LBS loosen the cable actually @ the shifter without doing anything @ the derailleur. Any advice on this ?
Thanks!
Thanks!
Quoted: 2026 Post(s)
Liked 1,095 Times
Bar end shifters can possibly be removed with out removing the cables by removing the screws that hold the levers to the body and pulling the levers off sideways. The bodies are removed from the bar end by loosening an expansion bolt inside the body.
However, the cables are threaded through the levers just like they are with downtube levers and held in place by the little knob at the cable end. They cannot be removed from the shift lever unless they are unfastened from the derailleur and pulled back through the housing. Also, the housing buts up against the shifter body so I don't see how you can get enough slack to actually remove the lever
