Bottom bracket
Bikes: Motobecane Mirage Pro
Bottom bracket
Curious, When I pedal I feel a hitch on the down stroke. It only happens once a revolution. I checked the crankarms and they appear to be tight. I think it could be the bottom bracket. Any suggestions?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
Check your rear derailleur pulleys to see if they are gunked out. Happend to me!
"How did all those 'Keep Off the Grass' signs get there?"
It could be you BB or your cranks. I had a hitch on my bike trip this fall with a new bike. I was expecting it as part of break-in for the new cranks (old style), but I hadn't been able to get a big crank tool to carry with me, up to that point all my cranks had used a hex bolt, the new ones use an 8mm tool. It was only solved when a pro with BIG wrenches cranked the pedals, the BB, and the cranks. What I usually do at home is pull the cranks, and lube the tapers, and then re-install. That works better than brute force. Not familiar with the new style cranks.
Bikes: Salsa Las Cruces, Burley R&R and a boat load of others.
I've resorted to using an 18" breaker bar with a deep 14 or 15mm socket. Could also use one of those big needle style torque wrench. The new style has a hex. Some are even self-extracting.
Bikes: Several road and around town bikes
Hair Dryer - I recently adjusted by bottom bracket bearings and the lock nut was frozen. (The large crome nut with square notches that needs a special wrench.) After being warmed up by a hair dryer and being banged by a small plastic hammer, the nut freed up.
I am not sure how this would work with the crank arms. Apparently aluminium expands faster than steel. But if things won't move a little heat my help free them up. They may be freer after they cool down.
