Any way to stop squeal in xtr v-brakes?!?
Do NOT give me all the regular answers like toe-in, sanding pads...etc. I have done it all. These brakes squeal because of vibration in the mechanism.. all those loose links. Just like brake squeal in a car, it is not caused by the rubbing of the pad on the rim, but the pad vibrating. Anyone have any experience with the avid ultimates?
I worked thin elastics between the links like bushings and tied them. Mine never did squeal, but it stopped the rattling going over bumps. Brake operation was not noticibly affected.
weather.com
cptn. x-chains sidekick
Bikes: stumpie, xtr, sid, ultimate sd
yeh i have the ultimates
in my opinion after working with xtr m960 v's... i feel the ultimates are far better...
as for brakes... the parallel push probably has developed a little slop (if they are older)* and needs an over haul
Originally Posted by Hank Rearden
Follow the link and spend the $5.25.
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
Had I known these existed, I might not have given my XT brakes away to a friend.
