tubeset suggestions?
Bikes: Ever changing..as of 2-24-09: 2003 Giant TCR Team Once, Sampson titanium, 1992 Paramount Series 3, 2003 Cervelo P3, 70s Raleigh Record fixed gear, 70s Fuji SL-12 commuter, mid 90s Klein MTB. Plus two or three frames lurking, plus 5 wife/kids rides
The "compact geometry" thread got me thinking. I am about to buy the tubeset for my first frame, and thought I'd troll for suggestions on tubesets. This will be my first "scratch built" frame, TIG welded steel, compact geometry, a 54 cm or so size. My goals are for the frame to be inexpensive (in case I screw anything up, and because I'm going to race on it), reasonably light, and stiff (I weigh 192 lbs).
I have some of the components for the bike; it'll use a carbon fork w/1" crmo steerer, mostly Ultegra parts (derailleurs/shifters/brakes/cranks). I have some reasonably light wheels; it needs an inexpensive stem and seatpost, and I should have enough parts to build my "race mutt".
I would like for it to come in under 20 lbs. Is that a reasonable goal for my less-than-exotic parts and a reasonably priced tubeset? Suggestions? I'm talking $100-150 here, if possible. I've previously bought some stuff from Nova and will probably go there for the tubes.
While probably true, that was less than useful.
I would like to hear some weights for built-up bikes; I know 17-18 lb bikes have been built with the newer tube sets, but I'd like to hear what a "typical" weight is with similar components and say, Zona tubing.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
Call some of the sources you are considering for tubesets. Henry James is a reputable dealer in S. CA. At 190 lbs, a lightweight frame may not be your most durable racing solution.
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Quoted: 8 Post(s)
Wildwood,
I'm doing exactly that next week; I have talked to Lon at Nova at length and I've been trying to get Bringheli on the phone.
Deanster04,
I've read the tubeset recommendations on Henry James' site, as well as most of the metallurgical and mechanical properties info I can find online. Currently, I am leaning toward a butted but not super thin choice like the Dedacciai 858 tubeset (.8/.5/.8) that Nova offers. Just thought I might get some info from a few people who've "been there, done that", as well as the suppliers.
Deanster04,
I'm also in the same boat. Going to be building my first frame and I know tubing selection is critical. 170 lbs 54cm track frame for NYC streets is the plan
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Originally Posted by KendallF
Wildwood,
Deanster04,
Deanster04,
Bringheli is way cheaper than Nova. Regarding the tubing, that .8/.5/.8 tubeset is called ZeroUno or Com12.5. It's a nice tubeset but too thin for a 190 lb'er in my opinon. I have a similar frame and can get derailleur rub at will, and I'm 165 lbs. I'd suggest using ZeroTre for the down tube and chain stays, that should firm up the bottom bracket quite a bit, and ZeroUno for everything else.
Good luck.
Ed
Industry Maven
Bikes: Thylacines...only Thylacines.
Stiffness is a result of tubing diameter, not wall thickness though. If you're building your first frame, wall thickness is an issue because it gives you a margin of error if you fry the tubes. Thats the reason to go thicker walled.
I talked to Bringheli today, and sent him an email to order a Zero (Sat 14.5?) tubeset. I understand it should be stiffer than the Zero Uno set (extra heat treat). Any input regarding this choice, Ed, Thylacine?
I am a new to bike frame building but I'm an experienced welder and have done a lot of thin tubing work (headers, intercooler piping), so I don't anticipate too much difficulty welding it up.
As far as stiffness in the bottom bracket area, I have seen a few people putting gussets on their frames at the bottom bracket area. I do this on race car stuff frequently; any reason not to consider it here?
Liked 425 Times
Liked 425 Times
Industry Maven
Which is stiffer - a ø35 tube at 0.7/0.5/0.7, or a ø31.8 tube at 0.8/0.6/0.8? I'm not a Physicist Nessism, but if you want a stiffer frame, I know which tube I'd select, and it isn't the latter.
I wouldn't worry about gussets, Kendall. Most are poorly designed and actually do the opposite that they're supposed to do and are pretty unnecessary on the road bike, even if you are 190lbs.
Liked 425 Times
