Bottom Bracket tool????
Hello everybody! I have a 2005 Norco Havoc and have a cracking noise coming from it. I have tightened the cranks to 300 lbs tourque but still never helped the cracking noise. I was thinking that maybe my bottom bracket needs to be tightened. But I have a problem. What tool should I use? It would be nice to check on e-bay to see if there is any there that could help me! Thanks alot!!!!
Custom User
Unless your BB is odd or an external bearing type, you'll likely need this:
https://www.parktool.com/products/det...5&item=BBT%2D2
later
you should check to make sure the chain ring bolts (the 4 bolts that attach the crank arm to the rings) are not loose, as well as that, your pedals could be loose too.
Bikes: 2005 Specialized hardrock pro... pike426, e.13 drs, fsa gap crank, formula k24's, and some more/2006 Scattante R-660 easton circuit wheels.
as for your issue, i'd second tightening your pedals or chainring...
good luck
Just incase it helps anyone, the noise only comes form the non-drive side (side with no chain, lol). Also it only happens when I put a nice bit of pressure on the pedel. (eg, when I pedel up hill) I just tightened the crank arm and pedel, but still no luck. It didn't help a single bit. Please help! I can't stand that noise!
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Are you sure the noise is coming from the BB and not the chain? Have you lubricated the chain recently?
- Wil
- Wil
