Sturmey Archer 3 Speed Project
times or divided by
Bikes: 2004 Jamis Komodo FX, Peugeot Super Sport(?), Trek SubVert bmx
I'm resurrecting an early 60's "Apollo" English 3 Speed. It has a Sturmey Archer AW hub stamped 1963. Overall the bike has very little wear on it, but all the chrome parts are pretty rusted up. It's not intended to be an all-original restoration, just a reliable ride. I got some nice alloy rims, alloy stem and straight bars, and Shimano 105 cranks to replace the cottereds and rusty chrome.
The original Sturmey shifter is in real rough shape, it's rusty and bashed up pretty badly. New replacement Sturmey shifters have crappy plastic all over them and are fairly expensive for what you get. Old all-metal Sturmey shifters in nice condition are rare and expensive on ebay.
I found a whole pile of NOS Shimano 3 speed shifters in the back of a LBS ($3 each with cable) , and was thinking of giving them a try. They have plastic on them, but are generally nicer than the plastic Sturmey ones. Does anyone know if they will properly shift an AW? It appears the cable pull is close enough to be worth a try, but I thought I'd mention it here anyway. I've also seen modern Sturmey twist-grip shifters on ebay, but they look a little sketchy. Suggestions?
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
You can get '70s-era Sturmey Archer shifters on eBay for less than $12. They have only one piece of plastic, the cover part that serves only to indicate what gear is where. (You can remove it if you'd like.)
I am under the impression that the Shimano shifters are not compatible. I think Sheldon says the twist-grip shifters are junk, but you might check on his site to be sure.
I tired of my Sturmey Archer shifter and replaced it with a downtube friction shifter. There's a learning curve involved in using it, and I wouldn't do it like this on someone else's bike. Should make it harder to steal, though, or at least harder for a thief to ride.
times or divided by
I like the friction shifter conversion, but being in the 'not my bike' category, I have to agree with you on that not being a good idea. I've seen the 70's Sturmey ones, and I know they're really not that bad, but for whatever reason I find myself utterly repulsed by them.
The Shimano 3 speed is only a slight (if any) improvement in quality, but I just like the feel of it a lot better.
It'd be funny to put a detent or secret mark or something on your friction shifter to set the hub in Neutral. That would make it even more confusing for would-be thieves.
如果你能讀了這個你講中文
THe shimano shifter cable pull is NOT compatible with the stumey cable pull. I guess shimano cut its teeth with sturmey before starting more stupid compatibility wars with campy and sram.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
I have the late 60s/ early 70s S-A shifter with clear plastic front on 2 of my Raleighs and I'm happy with both.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Don't go the twist grip route - I snapped the gear pin off inside the hub! But I have retrofitted a Shimano 3-speed shifter to a Sturmey-Archer 3-speed hub. Finding 1st and 3rd is easy (gear lever stops at extent of travel) - 2nd is more trickey. I experiment with lever placement and put a drop of bright model paint at the correct location. Although, this is for straight 3-speed hubs only - not coaster brake versions. If you don't get the gear just right on C.B.s it might slip when you back pedal - freewheeling when you expect the brake can cause painful (expensive) visits to the local ER.
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
I turned my '91 Schwinn Frontier into an "English 3-spd" with a '73 AW hub and a '67 S-A twist-grip shifter. I have noticed with this setup going from third to second twisting the shifter gets real hard where it doesn't seem to want to go into gear and then I have to let up slightly on the pressure for a moment and then it goes into second gear without a problem. And yes I'm letting off on the pedals, too.
I figure that if I keep shifting this way I shouldn't have any problems as long as I don't force anything!
I have also heard, I think from Sheldon Brown, that the British club racers back in the fourties and fifties never stood up on thier pedals when hammering in top gear because there was always a possibility of the hub slipping out of gear.
times or divided by
https://www.sheldonbrown.com/brandt/sturmey-archer.html
holyrollin'
They are cool bikes, but I don't understand why twist-grip shifters don't get the love. those things are great! When i can scavenge one of these setups I am an extremely happy camper, and one of my trigger-shifted frankenbikes soon gets converted.
